Motor and controller info pls
Geoffozz
Post by Geoffozz »
G’day folks
We have bought what appears to be a Kinetic brand motor and a Kelly controller. There is no plate or name on the motor. We did a Google image search and we think it is a Kinetic brand based on the grille around the brushes, however we didn’t get a link to a website with info on old motors. Is the Wayback machine my only option pls?
Re: Motor and controller info pls
Can you put some photos up? I'm sure we can identify it.
Geoffozz
Post by Geoffozz »
Thanks Chris. Here are a couple of shots. Apparently it came out of a Vitara, which has been converted back to petrol.
motor side view.jpg (130.75 KiB) Viewed 1671 times
motor top view.jpg (124 KiB) Viewed 1671 times
Well that would have been a backward step :lol:
Looks like a fairly ubiquitous forklift motor.
Hmmmmm
Are your sure this isn't one of those Goombi kits?!?
https://forums.aeva.asn.au/viewtopic.php?p=26891#p26891
Dan007a
Real Name: Daniel Andrews
Post by Dan007a »
Yeah that's what I thought at first but the ADC motor's I've seen have the vent+brushes at the rear of the motor.
And the rear of the motor isn't a solid plate against the body.
Its also short for an 8" motor.
I was trying to find if there was info on the vitara conversion.
Could always test the motor?!?
Geoffozz
Post by Geoffozz »
So this is interesting. The photos in this thread are as supplied by the seller and are of the motor we bought. I note that there is a very similar motor for sale on this forum in the classified section. viewtopic.php?f=34&t=6114
It even has the same builder's level holding it up. I'm going to guess someone has cornered the market for ex-Vitara motors! ;)
