Near completion of my EV Landrover,
First test run of AC51 today , everything hooked up correct , 100% soc 144v x 200AH pack , BMS running fine , no errors
Type 2 throttle , deadband & max programmed in spyglass . Max RPM from motor = 24 RPM , what am I missing ??
AC51 first start up Help
- Real Name: Don
Re: AC51 first start up Help
Problem solved, someone on diy electric car forum suggested I swap the phase cables on motor , despite the fact that they were correct as per labeling, this solved the problem , now spools up to 6500 smooth all the way
- jonescg
- Real Name: Chris Jones
Glad it was resolved quickly (pun not intended).
