Anyone used NCM (3.7V) cells in an EV? Thoughts?
Parts & Suppliers for EVs
aegidius
Real Name: Giles Puckett
Post by aegidius »
These cells are shown on EVPower's website (Shenzhen Westart I think). Advantage is higher voltage (fewer cells in a pack); disadvantage appears to be limited discharge current to 2C or less. Anyone used them, imported or bought them? Any other sources known?
Giles.
Re: Anyone used NCM (3.7V) cells in an EV? Thoughts?
James Hill used them in his endurance car (but he was pulling 0.2 C most of the time) I thought they were good for 5C or more?
Datasheet suggests 3C continuous and 10C burst.
It's only a disadvantage if you want a short range or a high performance ev.
