Hyosung 250 EV
gttool
Real Name: Geoff OToole
Hyosung 250 EV
Post by gttool » Mon, 04 Jan 2016, 14:47
My original bike has evolved and have basically a complete near bolt on kit to convert a 250 Hyosung to electric
Included..
Altrax 7245
Perm 132 + spare
wiring ( most )
contactor
estop
dc converter
welded 3mm aluminium mounting box for batteries and motor
front sprocket
bms and controller
the box bolts to the rear engine mount and 2 new holes are drilled at the front
the removable frame bar has to be straightened and a couple of washers are fitted to space this out slightly
requires batteries ( originally 60ah ts cells 72volts )
charger
inertia switch
throttle
really easy way to get an electric bike
check gttooling facebook to find pics of the bike
$1500 ono
Geoff
0410492581
Hyosung 250 EV
Post by Adverse Effects » Mon, 04 Jan 2016, 20:12
yep look at FB ummhmm no FB page with "gttooling" that i could find
there is a gt tooling but nothing about a bike on that page
Last edited by Adverse Effects on Mon, 04 Jan 2016, 09:21, edited 1 time in total.
gttool
Hyosung 250 EV
Post by gttool » Mon, 04 Jan 2016, 21:54
found but lots to look through
will post some other pics of the kit
https://www.facebook.com/media/set/?set ... 098&type=3
gttool
Hyosung 250 EV
Post by gttool » Tue, 05 Jan 2016, 02:38
Faz
Hyosung 250 EV
Post by Faz » Tue, 09 Feb 2016, 05:59
Hi, where is this located?
gttool
Hyosung 250 EV
Post by gttool » Tue, 09 Feb 2016, 12:05
Windsor Sydney
