Howard
Real Name: Howard Nutt
PIP-4048MS inverter
Post by Howard » Sat, 25 Mar 2017, 21:56
Hi All,
I'm new to the forum.Great to be able to contribute. Paukvk and I purchased eight PIP-4048WM VERSIONS(2015). One(mine) has been on line for about 2 years just out of warranty.Paulvk for about same time.
HAs been running well until last week or so when loaded up to 82A through batt/solar mode.Noticed smoke burning white smoke -blowing form fan exits-shut down and took off line immediately in view of stress,blowing Mosphets.Although no failure was noted but we suspected caps.(Underrated 3300uF 65v electros)
After calling GPower without much help was totally frustrated why main board could not be removed and was going to ask you?
Quite amazingly as I was working on the same problem at the same time on the same day(Yesterday) as you!!
Thanks soo much for the post because that is ONE sneaky screw under date code designation label!!!
Have done visual -no dc checks of Mosphets but noticed one of 3300uF 65V electros closest to rear of inverter light brown colour slight leakage component side between pcb and cap crimp rim diam.
So will research new caps,check mosphets and advise. Will probanly put this one back on line and replace cap on other PIP
Thanks again!!
PIP-4048MS inverter
Post by weber » Sun, 26 Mar 2017, 00:36
Welcome Howard. Yes., that Coulomb is one coul doud. Image
You're lucky you only got the sweet white smoke of Gandalf the capacitor and not the foul-smelling black smoke of Sauron the MOSFET. Image
Coulomb and I recently did an exhaustive search of Digikey, Mouser, RS Components and Element14, looking for suitable upgraded capacitors with an 80 V or more rating. This time we allowed for capacitors up to 22 mm in diameter, as previously one could only fit 18 mm. But we did not find any new option with low enough ESR or impedance, and high enough ripple current. So our recommendation for the capacitors is exactly the same as it was 2 years ago.
Here's the data sheet for the existing capacitors. I had to request this from the capacitor manufacturer. It seems it is a "special", i.e. not part of their standard line.
Jamicon WL-series 3300 uF 63 V 105°C 2000 hour
Here's our recommended upgrade.
United Chemi-con EKZN800ELL 182MM40S, 1800uF 80V 105°C 10,000 hour
Digikey part 565-4129-ND. Also available from other suppliers.
Here's my post from 2 years ago, in which you can read more details about this choice, and the slight hit taken on impedance and ripple current in return for voltage and endurance.
viewtopic.php?title=pip4048ms-inverter& ... 332#p56103
The existing MOSFETs are the 75 V IRFB3077.
A few weeks ago I listed 5 potential choices for upgrading these MOSFETs to 100 V.
viewtopic.php?title=pip4048ms-inverter& ... 332#p64007
We've since settled on the SUP70040E.
Digikey part SUP70040E-GE3-ND. May be available from other suppliers.
[Edit: We have since used the CSD19535KCS]
As with the capacitors, we've taken a slight hit on current ratings and on-resistance in return for the voltage rating, but the intention was that no spec should be significantly worse than that of the 75 V IRFB3307 used by the manufacturer two years ago.
I note that each inverter uses 4 of the capacitors and 16 of the MOSFETs. You may choose to replace only the capacitors, but you should definitely replace all four at once, even if only one has failed. The others won't be far behind. And since it is such a pain to get the board out, you might consider upgrading the MOSFETs at the same time.
Same goes if only half the MOSFET have blown. You should replace all 16 of them, and the 4 caps. [ Edit: but see this post about only replacing half of them under certain circumstances. ]
Yesterday at my place, Coulomb pre-emptively upgraded the MOSFETs and capacitors in his PIP, to the above choices. I have just heard that he has reinstalled the PIP and it is working fine.
But of course we cannot guarantee this upgrade. You do it at your own risk.
[ Edited Coulomb: removed then replaced degree symbols in preparation for phpBB conversion ]
Howard
PIP-4048MS inverter
Post by Howard » Sun, 26 Mar 2017, 01:40
Hi Weber ,
Thanks for that and first message ...Yep will do .Plan to do all that.Concur on mosphets and overall view.
We will need about 32 capacitors for all units.We were thinking about Nichicon for caps but have to check specs & bulk order?
You guys using earth straps on wrists?
Thanks again..no worries yes realize the risks.
PIP-4048MS inverter
Post by weber » Sun, 26 Mar 2017, 03:39
Hi Howard. We didn't bother with anti-static wrist straps because the humidity is so high here in Brisbane at the moment. Let's face it, it almost always is, except for a few weeks in winter. But they are a good idea.
We looked at Nichicon capacitors. We did not find any 80 V (or higher) Nichicons in 22 mm (or less) diameter with radial leads, with a low enough high-frequency-impedance and a high enough ripple current, along with a 105°C endurance rating of 2000 hours or more. If you think you might have found one, please point us at it.
I note that these are the important parameters in this application. The capacitance is utterly irrelevant.
Howard
PIP-4048MS inverter
Post by Howard » Mon, 27 Mar 2017, 18:52
Hi Weber,Thanks again for that.. Will advise on Nichicon caps either way-
Will get to parallel mode yet. Image
serbat
Real Name: paolo
PIP-4048MS inverter
Post by serbat » Wed, 29 Mar 2017, 22:49
Hello to all
Sorry for my bad English ..... (use google)
I wanted to ask Coulomb, information about the firmware "
The Latest Patched Firmware Description - dsp_Pb1_72.70b.zip "
I have three inverters, N°2 Mod PIP4048HS , and N°1 Mod ASK5000 Advance, do not use chargers inverter to charge the batteries, but use N°3 Western WRM30 mounted separately.
I 24 batteries in free acid "Plante" from 2V, (so in total 48V) of handicraft construction, which allow a minimum voltage of 40V to release.
And 'well it is known that the inverters currently use and which you know, unhooked the battery back in utility mode at 44V.
I wanted to understand whether the modified firmware allowed to lower this threshold to 40V everything else as it is now okay to me.
Thanks for your attention dedicated to me.
PIP-4048MS inverter
Post by coulomb » Thu, 30 Mar 2017, 03:06
serbat wrote:
Hello to all
Welcome to the forum.
I have three inverters, N°2 Mod PIP4048HS ,...
It's not clear to me whether the patched firmware (or the original manufacturer's firmware that they are based on) is suitable for the PIP-4048HS models. These have a maximum of 50 A solar charging (as opposed to 60 A for the PIP-4048MS. There could well be other firmware changes, since the Solar Charge Controller is completely different (PWM versus MPPT).
I strongly discourage use of the patched firmware on the PIP-4048HS models. If you do decide to try it, at minimum, you should have a way of going back to their original firmware, in case the patched firmware doesn't work, and somehow doesn't blow up the hardware.
What firmware version came with the PIP-4048HS inverter?
You seem to be saying that you have a very unusual lead-acid based battery that somehow is allowed to be discharged down to 1.67 V per 2.0 V nominal cell. I've never heard of such a battery, and everything I've read about lead acid batteries says that for longevity, one has to keep away from low terminal voltages.
So if I understand you correctly, you'd like a custom version of the lead-acid patched firmware that allows setting 12 to go down to 40.0 V instead of 44.0 V, with all other features being the same as the existing lead-acid patched firmware.
It's not obvious to me that it's safe for the inverter to operate at 40.0 VDC. The DC bus seems to operate at a fixed 8x the battery voltage, so when the battery voltage is at 40 VDC, the DC bus would be at 320 VDC, which is not enough to generate 230 VAC (230 x √2 = 325 V, plus MOSFET/IGBT voltage drops). So either it would generate less than 230 VAC, or it might attempt to generate 230 V with the tips of the sine wave clipped, causing poor power factor, possible electromagnetic interference, noise, and other problems.
Even if the patched firmware was safe for the PIP-4048HS model, and even if I was convinced that there are batteries for which it is safe to go down to 40.0 V, and even if I thought it was safe for the inverter to operate at 40 VDC,
I don't think it's a good use of resources to develop and maintain a special version of the firmware for one or a very few users. I have to draw the line somewhere. Sorry.
serbat
Real Name: paolo
PIP-4048MS inverter
Post by serbat » Thu, 30 Mar 2017, 05:53
Coulomb Thanks for the answer, very polite.
From some tests done, I saw that if I remove the 220V utility power while the drive is switched to "SBU", the inverter stays connected up to 40V before the change in "UTI" then trying to figure out if it was possible to activate this possibility inverter itself without the main switch, these batteries do not suffer from the problem on the voltage to 40V obviously I was advised to charge them within 24 hours.
A presisazione, I do not use internal inverter chargers to charge the batteries but use separate chargers, then the input of the inverter panels are disconnected.
In fact, the batteries which I am using as mentioned earlier is an artisan creation of an Italian boy, are decidedly robust batteries, in fact, both the positive plates and negative are in the lead with a thickness of 10mm and each battery weighs 70kg were formed with discharge School and refills without using any material paste on the plates, the oxides were formed only by the charging and discharging process.
Since they have not craft a technical dossier or a historical reference
The main problem of these batteries is that I should get as charge equalization at least 62V, which do not allow my inverter ...... but that's another problem.
Howard
PIP-4048MS inverter
Post by Howard » Thu, 30 Mar 2017, 14:56
Quick answer on Nichicon is no stock ..but can make volumes.
We are investigating these capacitors that this was not an O/volt issue but an ESR,temperature,(yes aging too) as they are mounted right next to heatsink.
It was as load ramped up to 82A from batteries inverting to 240VAC 4KW load that cap/s died.Have logged .pdf report if anyone is interested.
Will keep you all posted. Thanks!
Truka
Real Name: Dionisio Neves
PIP-4048MS inverter
Post by Truka » Tue, 11 Apr 2017, 09:48
Hello everyone .
After so much searching I did not find people as wise as here.
I come to ask for your help to repair my PIP.
When I changed a fan (with the problem already mentioned here) to another with the colors of the different wires, I shorted the wires and damaged the board.
I was very grateful to know the reference of the damaged components:
-D40 + C38 + ZD7 + R158 + ZD8
Thanks and greetings to all.
     Truka.
Always learning.
PIP-4048MS inverter
Post by coulomb » Wed, 12 Apr 2017, 06:35
Truka wrote: Hello everyone.
Welcome, Truka.
Sorry to hear you need to do that.
Interesting. But the parts you mention below seem to be part of the IGBT power supply; I would not think of these as related.
I was curious as to what that part of the circuit was doing. So I did a quick trace of it; see attached.
Warning: I've probably left parts out of this partial schematic.
Use your browser's controls (View Image, Open Image in New Tab, etc) to see the schematic in detail.
The Zener voltages and part numbers are a bit of a guess, based on my reading of tiny marking codes, and other markings on the parts that could be the real marking codes. I think it's making a negative supply of about 5.6 V, and a positive supply of up to 18 V, relative to the IGBT emitter, and isolated from the source of power (I can't find where those wires go; it has low resistance so presumably it's another transformer winding).
This circuit is repeated two more times. One of these power supplies runs three opto-coupled gate drivers; the other runs one. QB2 is one of the upper IGBTs of the 230 V inverter output full bridge.
The RS1J diodes are moderately fast 600 V rectifiers, with a tᵣᵣ of 250 ns, made by Vishay. Other similarly fast rectifiers, with any decent voltage rating should do. These are SMA (DO-214AC) sized devices.
[ Edit: Added warning; source -> emitter; added DO-214AC package size. ]
[ Edit: C11 -> C38. ]
[ Edit: Redrew so the power flow is left to right; indicate multi-winding inductor rather than transformer. ]
[ Edit: The schematic is now an attachment. Added schottky diodes. Replaced with up-to-date version with left-to-right flow. ]
[ Edit: Removed extraneous schottky diode; show lower transistor of U3 is MOSFET with diode; added SMD codes and part numbers ]
IGBT driver PS.png (46.35 KiB) Viewed 3539 times
Truka
PIP-4048MS inverter
Post by Truka » Thu, 13 Apr 2017, 07:56
Coulomb
Very grateful for the precious help.
I also do not understand if the fan connectors sit low on the board, and the burned components are on the top.
I can not find the capacitor C38. Thanks for your help.
Greetings to all.
    Truka.
(I do not understand how to send photos.)
Always learning.
PIP-4048MS inverter
Post by coulomb » Thu, 13 Apr 2017, 15:34
Truka wrote: I also do not understand if the fan connectors sit low on the board, and the burned components are on the top.
I think this could be a little mangled in the translation from Portuguese. I think you are remarking that the fan connectors are at one end of the main PCB, and these components are near the far end, so what could the connection be?
I'm thinking that somehow the voltage to the transformer primary (at the right end of my partial trace schematic diagram) was too high. Maybe it was because the fans were shorted out, and it was trying to raise the voltage to the fans, and this raised the voltage to other parts of the circuit as well. Or maybe it was some sort of transient.
Hopefully, the two zener diodes in series did their job, sacrificing themselves to protect other parts of the circuit. However, I'd check the other zener diodes and associated parts: ZD1,2, and ZD3,4. They are nearby; you can see them in the photo below.
I don't understand how you know that C38 has failed, if you can't find it. Did you get these parts designators from some repair manual or similar?
[ Edit: perhaps you mean you don't know how to find a suitable replacement. It is a bypass capacitor, so its value will not be critical. Any multilayer ceramic part of the right size (M1608? some suppliers still use the old imperial size 0603). Something like this (Mouser Portugal; I hope I got that right). ]
C38 is highlighted below; this is from an older (2014?) model:
The T350 opto coupled gate driver is one of five in a group, but I assume you already know where these parts are, to give their designators.
C24 is on the other side, with the 15k bleed resistor R158 across its leads. I'm surprised to hear that R158 is burned; its value is 15k; assuming it can dissipate 400 mW (total guess), it would need more than about 77 V to overload it. At that voltage, plenty of other components would burn up. Hopefully XD7 and ZD8 failed shorted, saving other components, but that would also include R158.
Years ago I wrote a post about how to attach photos to posts; I can't find it now. Maybe it's time to write another one.
[ Edit: I did, and you can find it here. ]
Truka
PIP-4048MS inverter
Post by Truka » Fri, 14 Apr 2017, 09:00
Coulomb, you're the best.
I mean, I did not see the C38 capacitor in your circuit.
Yes, the board is 2014.
thank you
Always learning.
Solar Junky
Real Name: Danny
PIP-4048MS inverter
Post by Solar Junky » Fri, 14 Apr 2017, 15:03
What's up guy's !!!
nice to see some new post.
Weber, trying to get a new module so my rs232 will work.
Thanks for your help!
PIP-4048MS inverter
Post by coulomb » Fri, 14 Apr 2017, 20:08
Truka wrote: I mean, I did not see the C38 capacitor in your circuit.
Oh! My bad. I copied a capacitor from another schematic, and it happened to be C11. I then forgot to change its designator to C38. It's the capacitor across ZD7.
Sorry about that, corrected now.
rinaldoparaipan
Real Name: Dan Paraipan
PIP-4048MS inverter
Post by rinaldoparaipan » Fri, 21 Apr 2017, 10:52
Hello again.
I have a strange situation with a PIP-4048.In the meniu 16 I set OSO(only solar charging)option.If I shut down the inverter from On-Off button and the AC grid is connected, after about 30 seconds the inverter try to start for few seconds: the LEDs and the display are lighting and after that is shutting down.The process is repeating continuously until I cut-of the AC in breaker.
Any idea?
PIP-4048MS inverter
Post by coulomb » Fri, 21 Apr 2017, 13:53
rinaldoparaipan wrote: I have a strange situation with a PIP-4048.
What main firmware are you running on that inverter?
When you say the LEDs are on before they go off, are they all on together for just a second or so, like at startup?
rinaldoparaipan
PIP-4048MS inverter
Post by rinaldoparaipan » Sat, 22 Apr 2017, 00:13
The firmware is 72.60.
Yes, the LEDs has the same behavior like at startup.
This happens not for one, but for two inverters-one is MPP Solar, the second one is Effekta(Voltronic branded for Germany)
Last edited by rinaldoparaipan on Fri, 21 Apr 2017, 14:16, edited 1 time in total.
PIP-4048MS inverter
Post by coulomb » Sun, 23 Apr 2017, 02:20
While reading through the firmware to possibly answer the above, I decided to search for a few keywords to see if perhaps Texas Instruments had published an application note with sample source code that Voltronic Power based part of their code on. I used "OSSched OSMaskEventPend" in a Google search. There were no results from TI, but it came up with this:
https://wenku.baidu.com/view/7915e57ca2 ... 5bfae.html###
It may take a moment for the PDF slides to show up in HTML format (a la http://www.alldatasheet.com/). In case it disappears, here is a sample page:
There it is. The definition for the real-time operating system Task Control Block structure. I have to say I was a little surprised to see that this was published in a scholarly presentation. Alas, I don't read Chinese, but the fact that source code seems to be always written in English means that there are chunks of readable code throughout. I've long wondered what the second and third fields were about.
If anyone knows how to translate such pages (Google Translate translates the text around the PDF, but nothing inside the PDF), I'd appreciate a pointer, perhaps via Private Message.
xenonhost
Real Name: Marian Titieni
PIP-4048MS inverter
Post by xenonhost » Sun, 23 Apr 2017, 13:14
Hello, everyone!
I want to buy LiFePO4 for my photovoltaic system but I need to know where to get a BMS for the cells and a remote monitoring device for the battery bank. I will buy the lithium cells from ev-power. At the moment I have 5 pcs PIP4048 in paralel which I haven't changed the firmware but I want to.
Any advice?
PIP-4048MS inverter
Post by coulomb » Mon, 24 Apr 2017, 19:39
Weber and I are preparing to do a MOSFET and capacitor upgrade to another PIP-4048MS. This one was manufactured in February 2017, and has different MOSFETs and capacitors to the ones we usually see. Wow. Could they have seen the light and upgraded to our recommended specifications, making such upgrades unnecessary from now on?
The MOSFETs are Texas Instruments CSD19505KCS. This is nearly the same part number as one of our recommended MOSFETs, the CSD19535KCS. The main difference is the MOSFET rated voltage; they are using 80 V compared to our recommended 100 V. With the lower voltage, they get better on resistance (2.6 mΩ versus 3.1 mΩ), but earlier models used the IRFB3307, which are 5.0 mΩ). So they've gone from 75 V to 80 V MOSFETs. This is probably adequate if the layout in the battery side of the inverter is exceptionally low inductance, but I don't believe that this is the case.
There are actually two different brands of 48 V bus capacitor installed in this particular inverter. One pair is Jamicon TK series 3300 μF 80 V capacitors. The 80 V is another improvement, in line with our recommendations. However, the TK series is "general purpose", though with 105°C rating. The rated life is only 2000 hours, compared to 10 000 hours for our recommended part. It also has a low ripple rating, around 2 A [ edit: at 120 Hz; see below ] (it's hard to find real data on this part; it may be a custom manufactured part). The original capacitors were rated at 4.57 A, so they've gone backwards in ripple current rating. It seems to me that in this application, ripple current rating is important, so again, their upgrades don't seem to have gone far enough.
The other pair of capacitors is Jainghai CD294 series 2200 μF 80 V. Again, the voltage is good, but the life (2000 h) and ripple current rating (2.1 A [ edit: at 120 Hz, see below ]) are poor. The CD294 doesn't seem to be a high ripple current series. The capacitance value (μF) is irrelevant in this application.
So the capacitors have improved in voltage rating, but worsened in ripple current rating. I don't know if this is overall an improvement or not.
[ EDIT: My bad! I've again been caught by the various manufacturers quoting ripple current rating at different frequencies, e.g. 120 Hz versus 100 kHz. Our recommended capacitor has a 120 Hz ripple current rating of 2.3 A, not much better than the Jianghai at 2.1 A, or the Jamicon at some 2.3 A. Without specifications at 100 kHz, it's hard to tell which is better. The mere fact that our recommended capacitor has a 100 kHz ripple rating, and that it's a member of a low ESR series, is indicative (but by no means proof of) better high ripple performance. ]
In summary, the improvements are basically welcome, but in our opinion don't go far enough. Still, it will be interesting to see if and how much the reliability improves with the 80 V MOSFETs and capacitors.
[ Edit: qualified "inverter" to "battery side of the inverter" ]
[ Edit2: Removed non-ascii characters in preparation for a forum conversion to phpBB ]
[ Edit3: Re-inserted UTF8 characters in preparation for testing another forum conversion to phpBB ]
joaquinsfy
Real Name: joaquin
PIP-4048MS inverter
Post by joaquinsfy » Tue, 25 Apr 2017, 04:06
Hi!
Finally is here!.
I have to update the firmware to start my installation, i want to install the 72.70b Firmware version, but i don't know if i need to install the PB version or the LF version. My installation is litihium iron chemistry (18650)
Thanks in advance, this can't be possible without your help.
PIP-4048MS inverter
Post by coulomb » Wed, 26 Apr 2017, 00:36
joaquinsfy wrote: I have to update the firmware to start my installation, i want to install the 72.70b Firmware version, but i don't know if i need to install the PB version or the LF version. My installation is litihium iron chemistry (18650)
Yes, the patched firmware has some unfortunate naming that doesn't reflect the realistic chance that someone, such as yourself, might use a non-LiFePO₄ but still lithium based battery. At least we've started calling the one with the extended voltage ranges the LiFePO₄ patch (it was the "lithium" patch).
To answer your question, basically only use the LiFePO₄ version of the patch if you actually have a LiFePO₄ battery. Yours appear to be 14s of a non-LiFePO₄ lithium chemistry, so you should use the so-called lead-acid version. You will be restricted, as with lead acid, to a maximum low-voltage cutoff of 48.0 V, which is some 3.43 volts per cell. I don't know your cells, but a quick search indicates that about 3.3 VPC is a reasonable figure. If you are indeed running 14s, you could use 46.2 V for setting 29, "Low DC cut-off voltage". You still have a little leeway if you want to increase that cut-off voltage.
The U1 display (DSP firmware version) will become Pb1, where Pb is the chemical symbol for lead. Just ignore that. We'll fix it as soon as we figure out how to capture "non-LiFePO₄" in two letters Image Maybe we'll settle on Fe (for LiFePO₄) and "St" (for standard battery voltage range).
It's not helped by the fact that people are starting to use the term "lithium ion" to mean "non-LiFePO₄ lithium based" (as I believe you did, joaquinsfy). LiFePO₄ (Lithium Iron Phosphate) is in fact one of the many chemistries under the "lithium ion" umbrella.
[ Edit: spelled out Lithium Iron Phosphate. ]
PIP-4048MS inverter
Post by weber » Wed, 26 Apr 2017, 02:37
joaquinsfy wrote:I have to update the firmware to start my installation, i want to install the 72.70b Firmware version, but i don't know if i need to install the PB version or the LF version. My installation is litihium iron chemistry (18650)
Hi joaquinsfy, You need to install the Pb version.
Your installation is lithium ion, not lithium iron. They sound the same, but they are very different things. The spelling matters.
