iMiEV tyre wear status
Yes, but pleasantly so.
Do read all of this thread for more info.
ZIPPIE11CAR
Post by ZIPPIE11CAR »
Post by reecho »
Yes steering is heavier with the Conti's.
But after driving on mine for a month or so I really don't notice it now. In fact the steering weight is very similar to my old Mitsubishi Colt Ralliart. Feels good now.
I have also changed my rears to Conti PremiumContact 2's. Slightly more noise but grip and stability has improved.
I must add that it appeared that the inside of my rear tyres was starting to break up. I would recommend that everybody with a 2010 with original rears to consider replacing them. 5 years max for Dunlops regardless of kms.
http://assets.inhabitat.com/wp-content/ ... 37x295.jpg
the URL needs to be between the bracketed URL flags.
best to use the full reply panel rather than quick reply ?
What ? they are not airless.... look at all that air Image
I wonder if the gaps fill up with stones ?
edit:clarity
ZIPPIE11CAR
Ok, cheers
yes airless space tires Image
You would hope its just to show the tech & that the do come covered on the sides Image
The pneumatic tyre really has stood the test of time. Quite amazing really.
Guess it shows how ICE world is really, slow to progress.
ZIPPIE11CAR
Just been knocked back twice today trying to get the 155's on the front.
They reckon you need min. 4.5 rims for the 155's to be legal :(
The Imiev's are 4.0 on the front.
Not fair
buy the tire's and fit them your self not hard to do
zzcoopej
Real Name: Jeremy
Post by zzcoopej »
ZIPPIE11CAR wrote: Just been knocked back twice today trying to get the 155's on the front.
That sux. I had Jax install 2 for me last week, no questions I just said another owner recommended them. $129 ea fitted (Erina, NSW)
Our full charge RR seems to have dropped however by about 5-10km, I need to check what pressure they inflated them to as I was running 38psi.
PS My daughter is about to do a year 9 science experiment regarding the power consumption of our iMiEV in D/eco/B, with different tyre pressures in the tyres etc (using CanIon to record trip data). I wish it had been underway when I swapped tyres!
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
ZIPPIE11CAR
Don't know if I would be keen on sacrificing 5-10 km range Image
AC motor believed it made no difference to his range?
ZIPPIE11CAR
Can any one else confirm a loss in range with the fats?
ZIPPIE11CAR
They wont sell them to me at all.
I'll keep snooping around.
Not keen on a reduction in range though...
Post by reecho »
nothing of note with my I-Miev....I changed all 4 tyres too...
Peter C in Canberra
Real Name: Peter Campbell
Post by Peter C in Canberra »
I didn't notice any loss of range with the 155 front tyres.
Last edited by Peter C in Canberra on Wed, 01 Apr 2015, 16:08, edited 1 time in total.
Nope. No apparent change in range. Actually, why should there be ?
Perhaps in a car park turning but not in general driving.
I run 40psi to try and get ever wear across tyres. See earlier posts. (Started at 38psi)
RR is never a good way to judge energy consumption.
Use canion or measure recharge kWh for km travelled.
The latter simply does not lie.
Tyre shop only has to refer to tyre manufacturer data to see that the iMiEV front rim is correct for 155 tyre.
Edit: spelng
zzcoopej
Real Name: Jeremy
Post by zzcoopej »
Agreed, and its most likely due to tyre pressure as tyre shops don't usually inflate > 34 unless you ask.
I really like the 155 tyres so thanks for the recommendation.
This will be useful for my daughters science experiment but I havn't seen recharge kWh reading in Canion, where is it? Or do you mean Wh/km driven or another figure? I was wanting to capture recharge kWh for her and thought I'd need to put an energy meter on the powerpoint which won't be as accurate as Canion.
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
carnut1100
Real Name: Greg Milligan
Post by carnut1100 »
Didn't notice any range drop going to 155s, no issue at the Bob Jane we got to fit them.
I run at 45 psi
Canion does not give recharge from the power point information.
Use an energy meter at the power point. This gives the completely independent and beyond question consumption from the wall. It is the Wh/km derived from this that allows true comparison between all plug in EVs.
Post by mikedufty »
Any recommendations for i-MiEV rear tyres in Perth?
We have a screw in one of the rears, tyre shop won't repair it because it is too close to the sidewall.
I'm now trying to decide whether to
-ignore it and pump the tyre up every week or so.
-do a DIY plug repair
-replace the tyre
-replace both rear tyres
The tyres are dunlop enesave 2030, original tyres with about 25,000 km and lots of tread. Would probably replace with the same if just changing one, but not sure if I want a half worn and a new tyre.
I suspect a plug will do a perfectly good job based on experience using them in on motorcycles a lot more powerful than an i-MiEV, but will probably be sensible and just replace the tyre, so interested if anyone has suggestions for where to get them in Perth. Several people have recommended the continentals for the front, has anyone tried anything different on the rear?
Post by reecho »
I replaced all 4 tyres on mine. I found the rears were starting to break up internally. I used Continental Ecocontact 2's on the rear IIRC.....same size...
Post by mikedufty »
Did you find somewhere that had them in stock or did you have to get them ordered in?
Post by reecho »
They were in stock at a local warehouse. Ordered and fitted the next day. Note they are noisier that the Dunlops. Grip however has greatly improved...
Gabz
Real Name: Gabriel Noronha
Post by Gabz »
Continental Ecocontact 2 are no longer available in australia we've been told.
Guy in Canberra just fitted
Achilles ATR-K Economist
but yet to here back on performance.
cruzxia
Post by cruzxia »
I just fitted Continental Econocontact 3 on the front. They are available. What a big improvement over the Dunlop's. The I Miev goes round corners without understear. It is like a different car. Can't say I noticed more or less road noise, so I guess it is almost the same as the Dunlop's.
zzcoopej
Real Name: Jeremy
Post by zzcoopej »
cruzxia wrote: I just fitted Continental Econocontact 3 ... The I Miev goes round corners without understear. It is like a different car.
I'm happy with my Continental 2's fitted a couple of months ago. The tyre dealer said he was getting the last 2 in the country, so must have been clearing out stock for the Continental 3's I guess.
I didn't think the iMiEV had much understeer until I took it to Eastern Creek Skidpan a couple of months ago. I had the Continental 2 fitted to the front and stock Dunlops on the rear, even let the front tyre pressure down from 38 to 30 and it still had plenty of understeer on the skidpan. I'd like to try swapping the front & rear wheels to see if that fixes the understeer if I ever do skidpan again (assuming the wider back tyres don't rub when used on the front). Or master a handbrake turn in the iMiEV, anyone tried it?
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
Post by mikedufty »
I decided to just replace the one tyre with an identical Dunlop. The local Kmart Tyre place said they supply them and would beat the tyres.com.au price, so it was about $160. They said they'd order one in, but didn't get back to me and when I called 3 days later said they were on backorder from Japan and would be 6 months.
At this stage the urgency of a reliable replacement was no longer there, and I decided to just plug it myself. So far the plug is working well.
