Do yourself a favour...
Post by jonescg » Thu, 07 Feb 2013, 01:06
...and buy yourself a set of these.
If you don't already have a set, you can get one from RS components. The two VDE spanners and the 12 mm socket were extra to the kit, but the whole lot came to about $1000.
It's a sh*tload of money, but in my circumstances it's a matter of life and life without eyesight (and possibly a defibrillated heart).
The red plastic stuff is considerably more resilient than PVC tape!
Canberra32
Real Name: Damian butcher
Post by Canberra32 » Thu, 07 Feb 2013, 01:14
It's plastic dip :) hard as nails :)
Even the cans of the stuff to dip your own tools are expensive :)
Post by Johny » Thu, 07 Feb 2013, 14:22
I just heatshrunk any tools that I was using.
Post by BigMouse » Thu, 07 Feb 2013, 23:23
Johny wrote: I just heatshrunk any tools that I was using.
Same. I have a set of insulated screwdrivers from Jaycar, and I just use the double-wall glue-lined heatshrink on everything else.
Post by jonescg » Thu, 07 Feb 2013, 23:28
Yeah, I figured 700 V was enough to warrant something a bit better engineered. Not that the pack will ever be at 700 V while I'm working on it, but handy nonetheless.
Post by Richo » Fri, 08 Feb 2013, 20:57
good call Image
Canberra32
Post by Canberra32 » Fri, 08 Feb 2013, 22:07
Pfffft just man up :p
Must be an AC owner thing...
DC owners cld totally take a 700volt hit and shake it off :P
Post by Richo » Sat, 09 Feb 2013, 00:01
Oh I could do it.
I could only do it once though Image
Canberra32
Post by Canberra32 » Sat, 09 Feb 2013, 02:37
Yeah I copped a 200amp sap from not earthing the tig and holding the metal :)
Got to say for 5 to 10 seconds I think I may have been strong as the hulk.
But 3 min later it was that feeling you get when winded but plus lactic acid :)
Post by coulomb » Sat, 09 Feb 2013, 03:43
Canberra32 wrote: Yeah I copped a 200amp sap from not earthing the tig and holding the metal :)
If 200 amps flowed through your body, you'd be turned into a fireball in less than a second.
After skin resistance is overcome, the human body has around a kilo-ohm of resistance (from poor memory, and I'm too lazy to look it up). Power equals I^R, so that's around 200^2 x 1000 = 40 megawatts.
The 200 amps only flows through a very low resistance circuit, like the welding wire and air heated to a plasma state.
[ Edit: and with E = I.R, it would take around 200 x 1000 = 200 kV to force 200 A through a human body. ]
Renard
Real Name: Robert Fox
Post by Renard » Sat, 09 Feb 2013, 14:27
50mA for 30ms kills you, or is it 30mA for 50ms?
Renard
Post by Adverse Effects » Sat, 09 Feb 2013, 19:44
only if it crosses the hart
Canberra32
Post by Canberra32 » Sat, 09 Feb 2013, 21:16
Yup but the HF of the tig is just a fun pulse :)
