Hi James got the bugs out of those controllers yet?
Start up torque is a big issue for any EV,
From my real world experience with EVs an 15 years experience with Drives used with rotating Industrial machines.
An alloy rotor motor gives you more start up torque point 1.
Most Ev applications are limited by the controllers current, so you want the most torque for the smallest amount of current right.
So I think it’s very relevant no one wants a sluggish EV.
Here is another case study for you but as you know an EV is a whole new ball game.
http://www.leonardo-energy.org/webfm_send/220
Starting torque
The copper rotor motor has the advantage of a high torque at running speed. Its starting
torque is lower than in aluminum rotor motors (85 Nm instead of 90 Nm in a 5.5 kW
motor), which is bene¯cial for gear box life. In applications where lower starting torque
is a problem, a modi¯ed design of the rotor slot o®ers a solution.
3.3 Higher start-up current
The higher conductivity of copper, i.e. its lower electrical resistance, will result in a
slightly higher start-up current (7.5 times the nominal current for a 7.5 kW copper rotor
motor, instead of 6.5 times for its aluminum counterpart). The use of a soft starter can
be used to avoid that this higher current a®ects the electricity system. Also, since motors
are increasingly being driven by inverters, inrush and starting currents become less of an
issue.
3.4 Rotor inertia
The higher rotor weight increases rotor inertia. This improves the motor's e±ciency, but
can be an problem in certain applications { for example motors that frequently switch
direction at high speed.
