Recumbent LWB cycle
david s
Recumbent LWB cycle
Post by david s »
I built this bike in 2000 and fitted it with a Currie and 24V LA batts in '02 It has been through a few sets of batteries and I upped the voltage to 30 V with an extra 6V connected in series in '03 The top end performance improved from 28Kph to 34Kph. Have recently fitted it with a Magic pie motor from Golden Motor and 48V lithium ion phosphate batt. It has regen. braking and cruise control (very nice) I fitted a front disc brake, no back brake connected yet. Performance now is 47Kph (on flat no wind or pedalling) and I will be interested to see if there is improvement when I fit the front and rear fairings. I think 47 is way quick enough round town, any more would be dangerous. I'd post a pic if I could find a way to get it to 100Kb
david s
Recumbent LWB cycle
Post by david s »
Try this. I hope the pic is big enough to see.
Recumbent LWB cycle
No pic Image
Make sure it is in jpg format and 640x480 is well big enough for a forum.
Use paint or picture manager(MS office) to resize.
david s
Recumbent LWB cycle
Post by david s »
It's a JPEG image 94 KB 525x394 uploading on an apple.
Gives a message "microsoft VB Script runtime error 1800a0035"
Recumbent LWB cycle
Hi David,
The forum has wacky problems sometimes.
Try renaming the file to something simple (lower case letters only) e.g. bike.jpg.
cheers
Edit: removed email address
Recumbent LWB cycle
This time for sure:
I didn't mod the jpg at all. I'm using firefox on linux if that makes a difference....
david s
Recumbent LWB cycle
Post by david s »
Thanks Woody,
On my way to work this morning I came off the bike. The combination of a small narrow front tyre and a disc brake on the front was not conducive to good adhesion over a wet white line. Fortunately I was only doing about 25 not 45. My round trip is 20 Km and the LED battery gauge still says I have full charge after getting home, although I'm sure it's closer to half.
david s
Recumbent LWB cycle
Post by david s »
My handlebars being steel were relatively heavy so I decided to make new ones in alum to reduce weight. As the steering stem is quite long I ended up with some flex. It made the handling awful, like driving a car with really sloppy steering. Because of the continual flexing the aluminium broke (fortunate,y at very low speed) and it's put me off the road. Lucky I wasn't doing 47, that would have been interesting having no brakes or steering at that speed. I've been way too busy building pizza ovens to get around to fixing the steering problem, but will certainly get it done during the coming holidays.
glenn_aircooled
Real Name: Glenn
Recumbent LWB cycle
Post by glenn_aircooled »
this looks an ideal commuting vehicle. How safe do you feel when motor vehicle traffic is around?
Do you feel that they " actually see you " .?
Cheers, Glenn.
Cheers , Glenn... I am working toward that happy " I never stop at Petrol Stations " feeling    :)
david s
Recumbent LWB cycle
Post by david s »
Have fitted an airhorn. My riding height is about the same as a normal sedan so I eyeball the drivers.
