Obsolete Thread
- Real Name: Rob Hills
I tend to lean towards plastic for light weight and also corrosion resistance. However, here you may also have to worry about UV resistance, any idea how the plastic will stand up to UV?
What about price, up front and also if it has to be replaced down the track?
FWIW, the shiny plastic one looks nicer and I like blue!
Rob Hills
AEVA Webmaster
Total Petrol: 756.3L
ODO: 67508
Av Consumption: 1.12 L/100km
AEVA Webmaster
ODO: 67508
- EV2Go
- Real Name: Paul
- Electrocycle
- Real Name: Andrew
- MSN: dumhed@dumhed.com
I found an old metal one I'm going to use on my bike because it's easier to modify
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- Speedily
- Real Name: Anthony
The green motor looks like its got a whole new end cap made
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- Speedily
lol This is how i'm doing it
one of the injector hats mit look good on the end of the intake
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- Johny
- Real Name: John Wright
It would be way more exciting (for us) if you ran the motor and held a hacksaw to the shaft.
No, I would not rest the armature on the field laminations while anything vibratary (word?) was done..
Edit: added 't'
Edit: added 't'
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- Johny
Agreed - just take is easy and check temp. every now and then.
Are you sure you don't want to think about this for a day or two?
Removing all of the rear-end of the shaft may make putting a tacho or encoder on to the motor a bit more difficult.
- EV2Go
- Real Name: Paul
- Speedily
Paul the criclip fan and spacer set the end float of the motor
- EV2Go
- Real Name: Paul
- Speedily
whats holding the front bearing inplace
- EV2Go
- Real Name: Paul
- AirAg
- Noobie
- Real Name: Peter Travers
How did you manage to get your menu items to link to your following posts? I have just been replying to my first post when I put up new stuff and it looks like the URL is the same for the whole topic.
Peter
