I also want one pedal driving.
Oh well it was only a matter of time before it got too much to bear.
I have been given permission by the big boss to fix this annoying problem.
When I modify the torque command I need to limit the torque so the regen power does not exceed 50kw which is the maximum that the car puts onto the battery during regen. So what happens is as the speed increases the available regen torque drops.FyKnight wrote: ↑Tue, 11 Oct 2022, 21:21 Wow that's fantastic Francisco! Well done!
KERS level 6 would be amazing.
Presumably the BMS would protect against this, but I'd be a little worried about not putting too many amps back into the pack when it is nearly full or a bit cold.
I've noticed that I can get up to 120A back into it when on the highway, but it needs the brake pedal to be lightly applied. If you could get that just by lifting off the accelerator that'd be perfect.
Where did you manage to get the connectors from? I've only tried plugging in to the OBD-II port so far...
I believe the BYD uses regen when the brakes are first/lightly applied. So not an issue with ACC.
I want to make an aftermarket kit. I need to wait to the end of Chinese New year tonsee if I can get the connectors and the parts.Billy2Hats wrote: ↑Sat, 21 Jan 2023, 09:39 Congratulations, brilliant! Will be interesting to see the general improvement to the range.
Do you have any plans to do these mods commercially, for either the two MG models or Atto 3?
The way I do the one pedal mode is not the same as what Tesla does. You get far more control over the regen than you do in a Tesla and it is very easy to coast without changing settings.Nagaman wrote: ↑Sat, 21 Jan 2023, 10:58 I’d simply like more of a trigger sensitive brake pedal cancellation of cc, instead of needing (what feels like) more than 3cm to activate regen. Our Tesla’s brake pedal is super sensitive. Either way one pedal driving is the ants pants for us.
My theory is that paddles and coasting are simply ways of pandering to the old entrenched loyal customers and, in particular, those scared of ‘losing control’.
Our Tesla’s regen transition to full used to be abrupt to the point of potentially dangerous in traffic due to phantom braking occurring, particularly if/when someone was tailgating ……imagine a cement truck.francisco.shi wrote: ↑Sun, 22 Jan 2023, 15:15 The way I do the one pedal mode is not the same as what Tesla does. You get far more control over the regen than you do in a Tesla and it is very easy to coast without changing settings.
The Tesla (and all other one pedal modes) have the regen drop as the car slows down. The closer the car gets to a stop the less braking force you get. With my method you get the full braking force all the way down to a stop. Because of this you can get considerably more braking force than with conventional methods.
If you watch the video you will notice the front suspension sagging from the weight transfer which doesn't happen on the Kona or the Teslas.
The regen braking is so effective and controllable that someone sitting in the car will think you are using the brakes.
You don't feel like you are missing anything because you haven't tried a better system. My daughter has a Tesla and when I drive it I most certainly notice the problem.
