Connect EVSE direct to meter?
Rubidium
Post by Rubidium »
Is it possible to wire an EVSE off the meter box, or does it have to go via the fusebox?
my meterbox is right next to where I would want the EVSE installed, but its far from the main fusebox which is inside the house and not on an exterior wall.
Re: Connect EVSE direct to meter?
If you can fit breakers in the meter box, then you can supply the charger from there, but it would technically be a sub board. I'm sure there's something in AS/NZS3000 about it.
AEVA National President, retiring WA branch chair.
Also a factor is your location - different networks will have different rules. But generally yes, a sub board of some form should be possible
2017 Renault zoe - 120'000km
2007 vectrix - 197'000km
2000 prius - trying plug in hybrid for a 3rd time
Bryce
Real Name: Bryce Gaton
Post by Bryce »
Short answer (am an electrician): sub-boards must come off the main switchboard. You could add it as a new main switchboard and the old one becomes a sub-board, but the cost would be way more than just going back to the main board.
Bryce
Current EV drive: 2019 Kona electric, 2010 iMiEV
