i-miev brought from Darwin
cr12330
Real Name: Joseph Chin
Post by cr12330 »
There was an i-miev that that was brought in Darwin recently, if you like to know more of the history of this, let me know as I can give a little more info and the battery situation.
https://www.pickles.com.au/damaged-salv ... /652119529
Thank you
zzcoopej
Real Name: Jeremy
Re: i-miev brought from Darwin
Post by zzcoopej »
cr12330 wrote: Mon, 26 Oct 2020, 07:06 There was an i-miev that that was brought in Darwin recently, if you like to know more of the history of this, let me know as I can give a little more info and the battery situation.
Yes I'm interested to hear about the SOH of the battery if you know what percentage of it's driving was done in NT?
Also, there looks to be damage on the drivers front door and passenger rear door only, what kind of accident was it in as the front and rear don't look damaged?
What are your plans for it, fix and drive, or use for parts only?
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
cr12330
Post by cr12330 »
It was a Demo car from Oueensland truck up to Darwin around 2013 with about 100 to 110km range on it, I first view this about late 2015 with the range being around the 93km mark, today the range is about 55km.
The car never been in an accident, the owner put a solar panel on the front bonnet to charge the car battery 12 volt which wasn't really required hence holes all over it.
I did put an offer down someone must of put a higher offer down and was glad it was picked up as it was sitting for 6 months doing nothing.
zzcoopej
Real Name: Jeremy
Post by zzcoopej »
cr12330 wrote: Mon, 26 Oct 2020, 11:32 today the range is about 55km.
Ah ok, thanks.
How much did you offer for it? They are going for $9k to $11k down here in NSW.
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
cr12330
Post by cr12330 »
It went for $3000 at the end, I didn't want to offer that much for it knowing that the battery range has dipped a lot, I knew if I had to put a 2nd hand battery in would of been another $8K to do that where I'm living etc. $3000 is still a bargain.
zzcoopej
Real Name: Jeremy
Post by zzcoopej »
$3k is a bargain if only for the motor and charging electronics etc.
2010 iMiEV
2015 PHEV Aspire
www.EvPositive.com
broombroom
Post by broombroom »
Is it just me, or is this Imiev now for sale in SA? Does anyone know what happened?
https://www.graysonline.com/lot/0001-60 ... k?spr=true
