So this official looking website, which professes to know all about all, has the Tesla M3SR+ as being no more efficient than it’s dual motor version which has a 50% larger battery capacity and conveniently goes exactly 50% further.
https://ev-database.org/imp/
EV comparisons (UK)
Re: EV comparisons (UK)
.....Er EV comparison
[ Edited Coulomb: Topic subject changed. You can change it yourself by editing the first post of the topic. ]
- EVdownUnder
- Real Name: Patrick Ulrich
I'm confused by your comment.
With equal efficiency, both 250Wh/mile, an EV with a 50% bigger battery SHOULD go exactly 50% further.
Did they get the battery size wrong?
Interestingly, if you choose metric instead of imperial, their efficiency are slightly different?
I love this website. A great place to see all EVs (only the ones available in EU but that is close to all of them).
As of 6 January 2021 (16 months of ownership)
46'000km at an average speed of 57km/h
125Wh/km from new
125Wh/km from new
The American EPA figures are more realistic to start with.EVdownUnder wrote: ↑Sat, 30 May 2020, 18:06 I'm confused by your comment.
Two motors increases your power losses which are generally considered to be around 20% (in this case x2 for the dual motor) and confirmed by the EPA’s figures......it’s basic physics.
The linked site is just rubbish AFAIC.
You took my charging spot the other day......if it’s the blue Kona)))))
- EVdownUnder
Sorry! Well that won't happen again as they fixed both cables and took the opportunity to set both of them to Tesla only. Disappointing.
And yes my parking technique was getting more and more inventive as the cable deteriorated more and more. Another month and I would have had to park my car upside-down to activate...
You are the blue M3?
125Wh/km from new
125Wh/km from new
[/quote]
No it’s the white SR+
HAL9K
Either way the centre needs to understand that just 2 outlets is just so unpredictable as to be useless for emergency planning purposes or to attract EV regulars.
[/quote]
HAL9K
- Real Name: Matthew Lacey
That depends upon whether core (magnetic) or copper (resistance) losses dominate
going to two motors doubles the (usually minimal) core losses but halves (ususally the more substantial) copper losses
going to a larger motor, or two motors tends to have higher efficiency across the operating envelope except at very low load (in which case in the two motor case one can be powered down)
- g4qber
- Real Name: Joseph
https://www.fueleconomy.gov/feg/topten.jsp
EPA Top 10 efficient EVs
One of the reasons I got the SR+
https://ev-database.org/compare/efficie ... -efficient
This sorts by efficiency
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 74
Me toog4qber wrote: ↑Wed, 03 Jun 2020, 18:10 https://www.fueleconomy.gov/feg/topten.jsp
The energy graph can be addictive
