Tritium fast chargers
Error 50 this evening
2020 Model 3 SR+ FSD - Delivered Fri 17 Jan ‘20 - k kms 82
Jasmin
Real Name: Jasmine
Post by Jasmin »
I wonder what it is that makes fast-charge points generally so unreliable? Compared to a petrol pump there are far fewer moving parts, so in theory they should be very simple and reliable. Is it substandard manufacturing, ,inadequate grid support, or something else...?
Who said petrol pumps are 100% reliable? How many times have you spotted a note or orange plastic cover over the gas pumps handle (out of order)
My guess is the issues we see with the fast chargers are safty fualts that perhaps will improve as they tweek the units to cope with the conditions they are operating in. A bit like a security camera you might need to turn down the sensitivity, and tweek a few things to stop nuisances alarms.
Jasmin
Real Name: Jasmine
Post by Jasmin »
Fair point about petrol pumps, and it *is* new tech, though not particularly complex. What I think would be a good move (and one I think we'll see in time) is fast-charge points being more like servos, with multiple "pumps". If one goes down (or is just busy / ICEd, or whatever else may crop up), there is some redundancy. It also makes the charge points prominent, so easy to find for the driver and highly visible to ICE owners, which can only be a good thing :)
Error 39
Error 50 CCS
Error 63 CCS
Error 95 CCS
Error 26 Uwa - comms to front display.
http://ozleaf.proboards.com/thread/805/ ... mmon-field
Undocumented err 188
Feng
Real Name: Matt Tse
Post by Feng »
I'm now at Wollongong and the UoW Veefil is giving an error 39 and saying the plugs aren't available. If there are any tricks to resetting it I'll be in the area the next few hours.
Get some security nuts and power cycle
Check out the errors at Uwa
University of Western Australia - Car Park 3 http://api.plugshare.com/view/location/57171
List of error codes found here.
dgh853
Real Name: David Hiley
Post by dgh853 »
Feng wrote: I'm now at Wollongong and the UoW Veefil is giving an error 39 and saying the plugs aren't available. If there are any tricks to resetting it I'll be in the area the next few hours.
Feng - did you get the charger working? Any photos of the charger/site?
Was thinking of trying it today.
2019 Tesla Model 3 SR+
2019 Kona Electric Elite
2013 Nissan Leaf
dgh853
Post by dgh853 »
g4qber wrote: Get some security nuts and power cycle
g4qber - what do you need to do to power cycle the Veefil - "Get some security nuts and power cycle" needs an explanation!
Thanks,
David
2013 Nissan Leaf
may need to get permission from uni first.
get this driver set
https://www.jaycar.com.au/the-power-dri ... t/p/TD2035
undo the 3 large nuts on the CCS pod side,
then undo smaller hex nuts on the bottom right service hatch cover
turn off the switches
wait for 2 mins
turn back on.
this doesn't work at UWA at the moment
"not in service" icon
remains
http://tritium.com.au/wp-content/upload ... Manual.pdf
Re: Tritium fast chargers
current - error 16
would be interesting to find out if elsewhere in the world have these errors
WA Veefil is prolly the beta test site for Tritium
firmware has been updated so that one can press & reset the e-stop button to power cycle the unit.
Thanks to Jayson for this tip.
good to see Aussie tech getting out into the world.
http://reneweconomy.com.au/tritium-boos ... d-40302397
new model charger to be installed at UWA 2nd week 2018.
will have CCS2
"Dear DC Station Users,
As you have already seen, the DC station at the Uni Club is still down and after several
repair attempts Tritium/Veefil have given up and decided to replace the station with a
newer model (after all, our station was the first CCS DC station in Australia).
Unfortunately, this means further delays, as Tritium does not have any spare stations
at the moment. At this stage we are looking at week 2 of Jan. 2018 to do the swap.
Sorry for this extended delay, but hopefully we’ll end up with a better product and a
more reliable solution.
Regards,
Thomas Braunl
New CCS type 2 / chademo Charger now more reliable apart from err 22 which usually means that chademo is not correctly connected.
Intermittent Error 28 since 11 oct 19 at UWA
Now persistent
Error 32 at gwelup Veefil reported by model 3
Error 39 then permanently stuck on error 131 when trying to charge with imiev
Joseph - any idea what these error codes are? I don't see a lot of value in listing them without context...
Found this
Tritium-Veefil-fault code.pdf
(69.08 KiB) Downloaded 125 times
And this
Tritium-Veefil-error-codes.pdf
(84.27 KiB) Downloaded 157 times
Courtesy of @g4qber on a leaf forum
UWA working since 25 nov ‘19
Gwelup ok since 4 dec ‘19
In case anyone cares, I added some images to the first post of this topic. The link to the original image is dead, and quite possibly changed long ago.
What’s the verdict on the Nz Veefil explosion?
https://i.stuff.co.nz/the-press/news/no ... canterbury
g4qber wrote: Tue, 28 Jan 2020, 06:50 What’s the verdict on the Nz Veefil explosion?
Not a good look, to be sure. My wild guess is that a capacitor emitted some sort of flammable fluid, which ignited somehow and caused the case to explode off.
It doesn't look like a massive electrical meltdown.
This was back in November; I saw a report that Tritium flew over a technician to investigate, but with a quick search can't find anything about the results.
Or some scallywag filled the inside of the case with butane and dropped a match?
