Fairly new to the EV charger world, but have been thrown in the deep end for a work project. Got a few technical questions on AC chargers, and what happens when you mix and match cars and chargers.
From what I have worked out so far, there are basically 3 common AC type 2 charger configurations:
'7.2kW' - Single Phase @30A - which covers most cars, as most have a single phase on-board chargers, and draw 30A or less.
'22kW' - 3 Phase @ 30A - which is basically the same as the above, but with a 3 phase contactor/supply rather than single - most cars will just use the red phase (so important to rotate charger supply from mains to evenly distribute load).
'11kW' - 3 Phase @15A as above, but with half the current rating.
Assuming most existing Type 2 on-board chargers are 20 - 30A single phase, if i plug one of these in to either the 7.2kW or 22kW charger, all should be ok - both chargers will supply it with power on the red phase, and will handle the 30Amps demand of the car.
What happens if I plug one of these cars into a 11kW charger, being a single phase load, does this effectively make the charger a 11/3 = 3.6kW charger, which most cars will exceed by defualt?
I understand the 1kHz comms between the charger and the car can request the car charger to slow down, but is this only after it has started charging? or will it negotiate before it starts - ie is an 11kW chargers signal not at 50% duty cycle initially, but at 25%, and work its way down from there if need be, causing the car to not start charging unless it can ensure it will not draw more than 15A?
Unless I am miss-understanding something - which is highly likely
