Model 3 Charging options in WA
- photomac
- Real Name: Matthew Clifton
Is there an issue using the RAC EV Highway? When I look at this website it suggests it will not be possible. https://jetcharge.com.au/resources/tool ... o-you-need
Yes, we can.
- reecho
- Real Name: Richard Baird
Re: Model 3 Charging options in WA
Some stations have been converted to CCS2. Check Plugshare for info...
- photomac
Thanks Reecho, that rings a bell from a few EV meetings ago.
Yes, we can.
- g4qber
- Real Name: Joseph
Harvey, Bunbury, Busselton, Dunsborough changed to ccs2
Others waiting on council funding.
$2500 per location to upgrade.
2011 i-MiEV - k kms 217
- Real Name: Matthew Lacey
Presumably you could still charge from the type 2 cable with the 22kw on board charger. Not as quick, but won't leave you stranded.
- photomac
I found this mobile charger, affirmations from some postings on these forum pages, whereby 1.5 to 22kW rate from GPO to 32A3P is feasible. Based upon my run from Perth to Esperance and back in LEAF v2.0 the available 32A3P sockets and Tesla destination chargers the sojourn would be worry free.
https://store.jetcharge.com.au/products ... b16a&_ss=r
Yes, we can.
- g4qber
- Real Name: Joseph
Model 3 only has 16.5kw AC onboard charger
- photomac
Dang - even lower at 11kW
https://www.tesla.com/en_AU/support/hom ... rd-charger
Which yields estimates to be ave 70km to 83km per hour. ( 15.6kWh - 13.0kWh / 100km )
Yes, we can.
- reecho
The superchargers at Eaton have been modified now with CCS2 connectors. So there's that...
- g4qber
- Real Name: Joseph
Mandurah now CCS2
https://www.plugshare.com/location/66217
