Kona EV Off Peak Charging
Hyundai Interest Group
vk6xre
Real Name: Robyn
Post by vk6xre » Tue, 21 May 2019, 08:34
Hi all, I have a Kona Launch Model. The scheduled off peak charging does not charge within the charging window. I have tried different EVSE units. I have tried setting different times. Nothing. It either charges 7 - 8 pm or refuses to charge at all. Unscheduled charging works fine.
Is anybody else suffering this issue?
Re: Kona EV Off Peak Charging
Post by g4qber » Tue, 21 May 2019, 08:40
Tis a bug. Right reecho?
2011 i-MiEV - k kms 195
Clintsc9
Real Name: Clinton Lovell
Post by Clintsc9 » Thu, 23 May 2019, 15:47
I haven't been able to get mine to work either so not worrying about it.
With my electricity supply the difference between peak and off-peak is 4 c/kWh. So a difference of $2.56 on a full charge from empty.
Clint
Post by reecho » Fri, 24 May 2019, 18:50
Yep. Every Kona worldwide suffers from the issue including mine. Fix in the works. Appears to be a bug in the radio firmware.
https://www.speakev.com/threads/schedul ... ng.138524/
vk6xre
Real Name: Robyn
Post by vk6xre » Tue, 11 Jun 2019, 22:53
I don't feel it is world wide just the AU and NZ Firmware versions. I have been to my dealer and they tested 2 Konas a Launch Model and a Highlander and they both suffered the same issues.
