i-miev Chademo port part
mark_hetho
Real Name: Mark Hetherington
Post by mark_hetho »
So I never thought there would be a compatible fast charger within range of home for the i-miev. But the NRMA has opened a public fast charger with a Chademo port near my work!
I'm hoping to track down an i-miev chademo port spare part, so I can try it out.
I believe I think have found the part on amayama for about $2100. This part is the port itself, plus the wiring harness into the pack. Given I've never needed a public charger and this is mostly out of curiosity I was hoping to track down a second hand one. So if anyone happens to be wrecking an imiev and doesn't want the chademo cable and port, I'd love to hear from you!
Re: i-miev Chademo port part
Does your imiev not already have a chademo port?
I thought that was standard equipment installed in all units
mark_hetho
Yes, it had one, but the main positive and negative pins are charred (and I think destroyed). I don't want to test that on a public charger and damage the charger. I've never had an impetus to replace it since there were no chademo chargers within range.
P.S. Be careful with high voltage DC.
mark_hetho wrote:
Mon, 27 May 2019, 11:17
Never seen a ChaDeMo port damaged like that. Take some photos and post them.
mark_hetho
This didn't happen from standard operating procedure. This is the result of an accidental short across the terminals from a multimeter that was plugged into the current shunt instead of the voltage socket. There was an arc-flash and lots of burnt carbon to clean off the rear quarter panel. So, yes it needs replacing. No, it should never be damaged like that.
It's a bit hard to photograph but here goes.
Looks like the pin got pushed backwards?
Yikes. OK yeah knackered. There's bound to be a spare one floating around the place...
