GPS for charging points
AngieD
Post by AngieD »
Hi there, new at this but wondering if any of the GPS units can show charging points for when we are on the road please?
Re: GPS for charging points
Many charge points need to activated with an app. I've found nextcharge to be useful, with maps integrated.
AngieD
Post by AngieD »
Thanks, I'll go and look at that site.
JD Solar and EV
Real Name: Jon
Post by JD Solar and EV »
Also check out Chargefox and Plugshare.
EVCS,AUS
Real Name: Greg
Post by EVCS,AUS »
Google Maps now has charger locations marked on their app and will soon show state of use.
