fuzzy-hair-man wrote:
I figure that taking off in an ICE by slipping the clutch is just letting the revs stay at a level where the engine is producing enough torque to take off without stalling, ie there is no mechanical advantage to slipping the clutch in fact it would waste energy as heat. Am I correct in this thinking?
I'd go with that, but add if your clutch slipping results in the RPMs dropping then you are trading some of the kinetic energy from the flywheel + engine for torque too - the extreme version of this dropping the clutch at redline.
So if I had a AC motor producing similar peak torque to the ICE and I can take off by slipping the clutch in the ICE then I should also be able to take off with a similar gearing using the AC motor right?
Sounds good to me.
Here's the problem though I'd be certain that I could take of in 2nd using the ICE (overall gearing ~ 6:1) but I can only find suitable size diffs to about 5.3:1 (Daihatsu Rocky or Suzuki Sierra) which puts the gearing somewhere between 2nd(6.5:1) and 3rd(4.6:1).
Working out 0-100km times and it actually makes it marginally quicker with a 5.3:1 diff than it does with a 6:1 diff but I don't think that tells me if it will be able to get moving in the first place. I'm not certain about these numbers either, could someone run some through their calculators to confirm?
I don't think stopped is a special case as far as acceleration goes.
As a bonus, the danfoss drive and presumably others can boost the torque at low speed above the peak torque of the motor to give you a head start. This lets acmotor get 337Nm from his 11kW motor at low speed, which is way more than you need.
Based from these
Specs , I reckon with:
Rolling Mini with Sierra Diff (450kg?)
ABB 4 pole 11kW 132 frame motor rewound for ~175 Volts (59 kg)
Danfoss 5042 controller (44 kg)
224 EVPST 2882118 12 Ah batteries (112kg)
Should have enough torque/power to do:
0-100 in 10s
400m in 17s
100km range at 65km (80% DoD as recommended)
Pack should last ~ 150,000km (1500 cycles)
Assuming you don't break anything.
The AC industrial motors don't get much smaller than that in weight and still give enough power/torque for a car.
Another guy has done a DC conversion using a Suzuki Swift gearbox, that may be suitable for the AC24 motor + drive combo (AU$8K before the dollar dived).
The AC24 torque curve is flat at ~74Nm up to 4500 rpm:
I prefer the industrial setup.
So how do you get an idea of what sort of direct drive gearing will suit?
PS: using the original gearbox is out because I don't think it would survive as they're weakish already and the mini gearbox might present troubles to try to connect to an electric motor, because the motor would need to sit on top of the gearbox.
I have a spreadsheet which I use which I put in the vehicle info and then jigger about with these variables:
1) Motor (from about 10 ABB models)
2) Motor Nominal Voltage @ 50Hz which affects nominal current etc.
3) Diff Ratio
4) Cell Model (e.g. Thundersky LFP40AHA, EVPST, Greensaver)
5) Number of Batteries I.E. pack voltage
6) Controller Model (e.g. Danfoss, Telemecanique, Lenze)
Just about all of the above affect weight which affects rolling resistance + acceleration, they also affect the torque curve of the motor through different limitations (Controller Motor Current, Battery Current, Cell Equivalent Series Resistance - ESR)
I muck around with those 6 things while watching the resulting 0-100 time and 400m time.
Of course I haven't got the whole picture, I reckon acmotor's Red Suzi should do 0-60 in 13s and he reckons it only takes 6-7s.
I haven't got anything to model the danfoss torque boost, which obviously makes a big difference.
Whichever way you go, you should be better than original 0-100 in 29.7 seconds
cheers,
Woody
