Labelling of Battery Compartment ???
goingbush
Real Name: Don
Post by goingbush »
My EV project is nearing completion,
reading through NCOP14
2.6 Labelling of Battery Compartments
Some batteries contain chemicals, particularly acids, which may cause a hazard in the event of a
crash. Each battery compartment should be labelled with the appropriate hazard symbols for the battery chemistry in use.
where does one obtain such labels , I have the usual lightning bolt stickers but they give no indication of chemistry, or do I just write "LiFePo4" on the boxes with a Sharpie ??
Re: Labelling of Battery Compartment ???
I think the yellow triangle with an exclamation mark / lightning bolt is the best option. A "Danger hazardous voltageges / Hazardous stuff inside" warning really. As there are no acids to vent there's no need for anything like "corrosive" and the like.
Post by rhills »
With regulations, you have to read every word carefully IMHO:
(my emphasis). To me that doesn't mean you have to specify what the battery chemistry is, just warn about the hazards "appropriate for" (or relevant to) that chemistry.
I think the rule would be better reworded:
Each battery compartment should be labelled with hazard symbols appropriate for the battery chemistry in use.
Total Petrol: 692.1L
ODO: 57409
Av Consumption: 1.21 L/100km
goingbush
Real Name: Don
Post by goingbush »
Excellent, thanks fellas . Yellow HAZV lightning bolt stickers it is then !!
Post by 4Springs »
goingbush wrote:
Sun, 24 Dec 2017, 08:02
My interpretation led me to get some yellow labels made up:
These were made by my local trophy shop. It is that stuff that is two colours of plastic, with the top yellow layer removed to expose the black bottom layer. I had six(!) battery boxes to label. When I went to lithium batteries I had new ones made that say (I think) "Contains Lithium (LFP) Batteries".
They were not expensive - from memory less than $5 each. You can see that this one is held on with a screw at each end. When the label is heated by the sun it expands and bows up - slightly annoying at car shows. I'd recommend not using that method of fixing such labels.
I had an interesting conversation with an emergency services volunteer at our recent car show in Devonport. She was asking what should she be considering when approaching a rolled electric or hybrid vehicle. I showed her the orange conduit on a couple of cars, and told her that each model and home-build will have an isolation switch. I also told her that turning the car off (I showed her an Outlander off button as an example) should disable all electrics - this was not part of her training for ICE vehicles and she hadn't considered it. Her issue with the battery boxes was that if she needed to cut through a vehicle she'd like to know what was in there. Another thought is that if there was a squashed box with goo seeping out onto someone's skin, a label would mean she could look up the MSDS to see what it was.
So I guess I'm saying that a bit of a description might be a good thing.
4Springs wrote:
Mon, 01 Jan 2018, 17:31
Ask them to put 3M MP467 or similar on it next time.
They should have this already in the shop.
You can still use the screws.
