Netgain introduces an AC motor
http://www.go-ev.com/20170808_files/PR20170808.html
They're using a Synchronous Reluctance Internal Permanent Magnet (SRIPM) motor. Interesting that they see the value for money advantage DC presently holds will disappear in about 5 years, per this post on DIYelectriccar.com.
[ Edit: SRIPM seems to be a fancy name for the type of motor that is in many EVs and hybrids including the Prius 20 years ago, the "Interior Permanent Magnet" (IPM) motor. ]
goingbush
Real Name: Don
Re: Netgain introduces an AC motor
Post by goingbush »
Too bad, I just paid for my HPEVS AC51 two months ago and it was just delivered, I would have jumped on this at almost $2000 cheaper !! and the specs look better for my purpose !!
It looks quite nice.
But the whole system looks about AUD$7,200 landed for 100kW peak.
Which seems a tad over priced over a regular induction motor of similar spec.
The power graph for that suggests 1,200 RPM before it hits the voltage limit.
Seems quite low.
Perhaps this is so they can release a new controller later using the same motor that does 200kW at 2,500RPM :shock:
Now that'd be more like it :twisted:
I don't see a price anywhere for just the motor.
goingbush
Real Name: Don
Post by goingbush »
$5700 for the motor and controller at EV Works
http://www.evworks.com.au/hyper-9-is
$7,200 is buying it from a retailer in US, shipping, duty and taxes.
Even better that EV works list them for less.
But that controller is still underrated...
It's like the difference between a stock 4cyl lancer and V6 commodore in performance.
