Known issue.
Now I have experienced it.
After using petrol to get to Albany.
http://www.mybmwi3.com/forum/viewtopic.php?f=13&t=2527
Can't open fuel port on Rex
- g4qber
- Real Name: Joseph
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 76
Did you have to use the manual release? Did it work?
- g4qber
- Real Name: Joseph
Yes had to use it
Manual release worked
- g4qber
- Real Name: Joseph
Fault again last weekend at Harvey
Ok for now
Ok for now
- g4qber
- Real Name: Joseph
waiting for Fuel Flap actuator from Germany
had to do manual mode 2x during Targawest
Fuel flap cover was almost lost too as it slides into place.
Another thing that "almost" fell off
Items that have fallen off since new:
a) door reflectors
b) front right BMW badge
a) door reflectors
- g4qber
- Real Name: Joseph
Fuel flap actuator arrived.
Will be Ev less till Monday
- g4qber
- Real Name: Joseph
Pressure sensor ordered from Germany.
12 working day delivery time.
- g4qber
- Real Name: Joseph
Fuel flap fixed now hopefully.
They fixed it early.
Re: Can't open fuel port on Rex
I had the same problem on mine, used the manual release a couple of times, and now the button release seems to be working again ?!? " Looking into" the problem would have required all day to run "diagnostics" on the car and cost $270 (out of warranty).
