Can't open fuel port on Rex
BMW i3 discussion forum
Known issue.
Now I have experienced it.
After using petrol to get to Albany.
http://www.mybmwi3.com/forum/viewtopic.php?f=13&t=2527
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 59
Did you have to use the manual release? Did it work?
Yes had to use it
Manual release worked
Fault again last weekend at Harvey
Ok for now
waiting for Fuel Flap actuator from Germany
had to do manual mode 2x during Targawest
Fuel flap cover was almost lost too as it slides into place.
Another thing that "almost" fell off
Items that have fallen off since new:
a) door reflectors
b) front right BMW badge
Fuel flap actuator arrived.
Will be Ev less till Monday
Pressure sensor ordered from Germany.
12 working day delivery time.
Fuel flap fixed now hopefully.
They fixed it early.
johc
Real Name: John Croker
Re: Can't open fuel port on Rex
Post by johc »
I had the same problem on mine, used the manual release a couple of times, and now the button release seems to be working again ?!? " Looking into" the problem would have required all day to run "diagnostics" on the car and cost $270 (out of warranty).
