Hit a Kangaroo at 50kmh
Post by g4qber » Thu, 10 Mar 2016, 14:35
small dent in front bonnet
plastic faring is also a bit deformed
no damage to lights
now washer fluid is leaking
what is behind there?
2011 i-MiEV - k kms 205
Rusdy
Real Name: Rusdy
Post by Rusdy » Thu, 10 Mar 2016, 16:21
Ouch! Is this your i3 or iMiev?
Post by reecho » Thu, 10 Mar 2016, 19:25
Probably busted the water bottle or pump...
Post by g4qber » Thu, 10 Mar 2016, 20:24
Imiev
That is why this post is in the Mitsubishi folder
Washer Water pump still makes sound
Post by reecho » Thu, 10 Mar 2016, 21:15
2 x busted cars now....
Sheesh....
Malm
Real Name: João Ricardo Soares
AIM: Est. da Lameira, Ed. Choupal, Bl. A , 2º D
Post by Malm » Fri, 11 Mar 2016, 13:46
Sorry about your i-MiEV and the kangaroo. That will sure not happen to me, since it will be very difficult to find one around here.
I-MiEV owner from Portugal - 81000 km
Post by offgridQLD » Fri, 11 Mar 2016, 16:49
That's bad luck,
               though speed was low and it sounds minor and repairable. Open the bonnet and just make sure nothing has pushed back into the coolant tanks or brake fluid.
A pic or two of the damage would paint the picture more.
Post by g4qber » Fri, 11 Mar 2016, 18:36
Post by mikedufty » Fri, 11 Mar 2016, 23:08
Malm wrote: Sorry about your i-MiEV and the kangaroo. That will sure not happen to me, since it will be very difficult to find one around here.
You never know. There is apparently a wild population of Wallabies near Paris, they might spread.
http://www.telegraph.co.uk/news/worldne ... orest.html
Post by coulomb » Sat, 12 Mar 2016, 01:30
Joseph,
I see you spotted a red MX-5 with the WA number plate "198 VOLTS". I also see two other photos of this vehicle on that Facebook page. Whose it it? Any details? I can't seem to find any.
Post by g4qber » Sat, 12 Mar 2016, 04:19
Peter C in Canberra
Real Name: Peter Campbell
Post by Peter C in Canberra » Sat, 12 Mar 2016, 22:46
I thought I heard of somewhere in your part of the world where there was a small population of feral wallabies. Perhaps it was France or England.
Edit: Oops. Read on further and saw it is France.
Last edited by Peter C in Canberra on Sat, 12 Mar 2016, 11:49, edited 1 time in total.
Post by g4qber » Thu, 31 Mar 2016, 12:22
Almost hit same? Kangaroo with bmw.
23.30.
Same spot.
Note to self slow down and look for kanga. Around midnight. Also use high beam.
Post by offgridQLD » Thu, 31 Mar 2016, 14:28
"Almost hit same? Kangaroo with bmw.
23.30.
Same spot.
Note to self slow down and look for kanga. Around midnight. Also use high beam."
Sounds like you need a bull bar and side bars fitted to your Imiev and I3 Image
something like this would be fitting for the ImievImage
carnut1100
Real Name: Greg Milligan
Post by carnut1100 » Thu, 26 May 2016, 03:06
I had two wallaby strikes while i had the imiev...
Simon
Real Name: Simon
Post by Simon » Thu, 26 May 2016, 04:09
I had a near miss with a big kangaroo in my dad's Leaf. It was on a very quiet country road after dark, glad I was traveling at 70kph instead of the 100kph speed limit! Sat at 60kph after that and a few km up the road I nearly hit an owl in the middle of the road. Sometimes EV's are just too quiet.
