Hit a Kangaroo at 50kmh
- g4qber
- Real Name: Joseph
small dent in front bonnet
plastic faring is also a bit deformed
no damage to lights
now washer fluid is leaking
what is behind there?
no damage to lights
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 74
- Real Name: Rusdy
Ouch! Is this your i3 or iMiev?
Probably busted the water bottle or pump...
- g4qber
- Real Name: Joseph
Imiev
That is why this post is in the Mitsubishi folder
Washer Water pump still makes sound
2 x busted cars now....
Sheesh....
Sheesh....
- Real Name: João Ricardo Soares
- AIM: Est. da Lameira, Ed. Choupal, Bl. A , 2º D
Sorry about your i-MiEV and the kangaroo. That will sure not happen to me, since it will be very difficult to find one around here.
I-MiEV owner from Portugal - 81000 km
- offgridQLD
- Real Name: Kurt
That's bad luck,
though speed was low and it sounds minor and repairable. Open the bonnet and just make sure nothing has pushed back into the coolant tanks or brake fluid.
A pic or two of the damage would paint the picture more.
- g4qber
- Real Name: Joseph
- Real Name: Michael Dufty
Malm wrote: Sorry about your i-MiEV and the kangaroo. That will sure not happen to me, since it will be very difficult to find one around here.
You never know. There is apparently a wild population of Wallabies near Paris, they might spread.
http://www.telegraph.co.uk/news/worldne ... orest.html
g4qber wrote: https://www.facebook.com/groups/1478582 ... 478063809/
Joseph,
I see you spotted a red MX-5 with the WA number plate "198 VOLTS". I also see two other photos of this vehicle on that Facebook page. Whose it it? Any details? I can't seem to find any.
- g4qber
- Real Name: Joseph
- Real Name: Peter Campbell
I thought I heard of somewhere in your part of the world where there was a small population of feral wallabies. Perhaps it was France or England.
Edit: Oops. Read on further and saw it is France.
Last edited by Peter C in Canberra on Sat, 12 Mar 2016, 11:49, edited 1 time in total.
- g4qber
- Real Name: Joseph
Almost hit same? Kangaroo with bmw.
23.30.
Same spot.
Note to self slow down and look for kanga. Around midnight. Also use high beam.
23.30.
Same spot.
- offgridQLD
- Real Name: Kurt
"Almost hit same? Kangaroo with bmw.
23.30.
Same spot.
Note to self slow down and look for kanga. Around midnight. Also use high beam."
Sounds like you need a bull bar and side bars fitted to your Imiev and I3
something like this would be fitting for the Imiev
23.30.
Same spot.
- carnut1100
- Real Name: Greg Milligan
I had two wallaby strikes while i had the imiev...
- Simon
- Real Name: Simon
I had a near miss with a big kangaroo in my dad's Leaf. It was on a very quiet country road after dark, glad I was traveling at 70kph instead of the 100kph speed limit! Sat at 60kph after that and a few km up the road I nearly hit an owl in the middle of the road. Sometimes EV's are just too quiet.
