i3 wheel alignment
BMW EV Interest Group
i3 wheel alignment
Post by g4qber » Wed, 05 Aug 2015, 15:19
$166.70 - wheel alignment check KDS
$150.03 - adjusting rear axle and front axle
$31.67 - tax
$348.40 total
2011 i-MiEV - k kms 205
i3 wheel alignment
Post by offgridQLD » Thu, 06 Aug 2015, 02:38
Wheel alignment check KDS $166.70 -
Adjusting rear axle and front axle $150.03 -
Knowing you could have got it done at Bob Jane for $ 60 priceless.
i3 wheel alignment
Post by g4qber » Thu, 06 Aug 2015, 09:18
Bob Jane don't have the i3 specs
bladecar
i3 wheel alignment
Post by bladecar » Thu, 06 Aug 2015, 14:58
Bob Jane should obtain the i3 specs (if when you take out a contract to buy your car, you subsequently own it).
i3 wheel alignment
Post by offgridQLD » Fri, 07 Aug 2015, 01:55
I'm sure you can find out the specs.
Even if for some silly reason you cant. Perhaps while you know it's been set now (assuming they actually did anything). Take your car to BobJane or some other independent shop and get them to put it on there wheel alignment machine and print out the readings. Then next time you have reason to believe you need a wheel alignment then you have the specs.
Then again if your happy paying five times more than you should just continue to take it to BMW.
i3 wheel alignment
Post by reecho » Fri, 07 Aug 2015, 01:57
Wheel alignment huh...
Was it out from the original spec?
Generally it changes if either you hit things strong enough to bend components or suspension parts are wearing and changing geometry.
The latter is generally a warranty item.
