Portable CHAdeMO
- markrmarkr
- Real Name: Mark Roberts
Portable CHAdeMO
I've been keeping an eye on developments at http://www.emotorwerks.com/ and I really think we are on the cusp of a much cheaper 3-phase to CHAdeMO which is portable (as in you can put it in your boot). There is some fugliness in the approach, but it looks viable.
The cost I'm expecting will be under $5,000 AUD, perhaps well under.
If this works out it will be possible for one person or organisation (say AEVA) to buy the unit and hire it out to individuals or members who want to go on a road trip in their EV(s).
Of course then we have the problem that there has to be sufficient 3-phase outlets along the route. But at least it is a step in the right direction.
Thoughts?
Thoughts?
- acmotor
- Real Name: Tuarn
Portable CHAdeMO
Yes, good the price is coming down.
I am quite disgusted at the present CHAdeMO charger prices, they strangle the expansion of the EV charging network.
The quantity of power electronics and CAN bus control equipment in a CHAdeMO charger is far less than the VFD already in your EV.
It appears than many chargers use 50Hz 3phase isolation transformers of 30 to 50 kW rating. These are heavy and copper expensive, hundreds of kg and thousands of $.
These newer technology chargers use HF transformers for isolation with the resulting drop in cost, weight and power loss.
Basically...
3 phase bridge rectify incoming mains, with attention to RFI and PF
HF inverter via HF transformer at least 50 kHz provides isolation as required by EV, actual current and voltage control is done in this stage
Rectify and supply via CHAdeMO connector to the EV
The CAN bus handshake with EV along with charger and safety interlocks applied by supervisory micro processor.
Box it up with some fancy graphics and $5,000 is still over the top.
However, as Mark points out, finding the 3 phase outlets is the next challenge.
32A gives just over 20kW and 64A just over 40kW
At least these are a lot cheaper to install than present CHAdeMO chargers $40k ++
Surely this is all transitional though..... The EV manufacturers will install ( dual purpose ? ) large chargers in EVs or the Tesla model of pushing chargers into the community will prevail ?
The fear is that, like printer cartridges, there is an intent to control your EV charging for commercial / taxation reasons. Sorry... Skeptic there.
Basically...
- markrmarkr
Portable CHAdeMO
The CHAdeMO emotorwerks is working towards will do 20kW at least, 40kW may have to wait.
I think your fears of our EVs being "managed" against our wishes are well founded, however this approach (portable CHAdeMO) gives us a way around it. Hell, I'll tow a 3-phase generator behind the car before I go back to dealer controlled warranty and maintenance, and all that implies. Ehh!
- acmotor
- Real Name: Tuarn
Portable CHAdeMO
markrmarkr wrote: ..... Hell, I'll tow a 3-phase generator behind the car before I go back to dealer controlled warranty and maintenance, and all that implies. Ehh!
Fair sentiment. There does seem to be too much profit without value adding.
Though I'd tow 20kWh of batteries behind before going he hybrid direction.
- g4qber
- Real Name: Joseph
Portable CHAdeMO
http://www.quickchargepower.com
upgrade your EV conversion to CHAdeMO soon.
found out about them on EV West's EV Show
http://insideevs.com/new-ev-show-episod ... demo-rav4/
they are currently doing tests on their RAV4 EV.
http://www.myrav4ev.com/forum/viewtopic.php?f=9&t=849
2020 Model 3 SR+ FSD - Delivered Fri 17 Jan ‘20 - k kms 80
Portable CHAdeMO
So has anyone seen evidence of a ChaDeMo kit for EV conversions in use?
http://shop.quickchargepower.com/CHAdeM ... qscsfapp03
Looks the goods, but has anyone ever installed this on their converted car? What's the CAN signal the charger is looking for? And does this gizmo exist? There's probably a decent market for retrofitting vehicles with the above kit...
Portable CHAdeMO
jonescg wrote: So has anyone seen evidence of a ChaDeMo kit for EV conversions in use?
So that's US$800 (I presume US$) plus shipping, and they don't ship to Australia or nearly anywhere else. Just for the inlet and a metre of cord.
For home conversions, I think this is not practical, especially if you wanted to use the chademo to 3-phase adapter. Why not put a 3-phase charger in the boot, connected by a beefy finger-safe anderson or other more moderately priced connector?
Of course, if you have access to a real chademo charger, then it might be worth the expense of the connectors and figuring out the reportedly complex protocol. I believe it's one of those closed protocols, where you have to pay heaps to get the info on it, and pay more to get certified as compatible as well. It just doesn't sound DIY to me.
I'm afraid that I don't agree with ACmotor's statement that $5000 would be overkill for a chademo-like charger. It's a serious power switching device with cooling and EMI issues. The actual charge algorithm is up to the car, but that would be the simplest part of a 50,000 W charger (or even a 20,000 W or 10,000 W charger if you were doing a cut down version). A real chademo charger has to be able to handle a wide range of pack voltages (though "only" up to 500 V, so not enough for at least several conversions in Australia), though again you could cut down on the voltage range for a particular car or a few models.
Portable CHAdeMO
EVTV is working on a kit with a Yazaki harness and the JLD505 CAN module. Damien Maguire is working hard to debug the firmware. Results are amazing so far...
Check out the following Youtube video on his "Land Yacht"....
Youtube
Bear in mind some development work may be required for stations such as Veefil that they haven't been able to try directly and debug.
Maybe under $1500 for a full kit. Plus some install and debug work. Almost a no brainer for modern conversions....
Youtube
Portable CHAdeMO
That's that I was thinking - I don't need a fast charger in my garage, I just want a fast charge inlet on my conversion so I can use the fast chargers on the Electric Highway. If it ends up costing more than $6k I'd be better off buying a Brusa charger and making a 22 kW Mennekes 'Fast AC' adapter. The slow AC can be a 7 kW AC charger with a J1772 inlet.
Portable CHAdeMO
Chademo JLD505 Manual for those interested....
- g4qber
- Real Name: Joseph
Portable CHAdeMO
