I regularly ride 40km to work - amazing what your body gets used to quickly.
woody wrote: 2 days too early on your post
Yeah, my work is 15km away, and I can ride to work in my steel-capped boots, do a 10 hour day and ride back again without any kind of "bike fitness". That is, I can do this even if I haven't ridden a bike for a couple of months. Uses even less fuel than my EV!woody wrote:I regularly ride 40km to work - amazing what your body gets used to quickly.
Thalass wrote: Wow those are great numbers on the lithium pack. I'm sure with their longer life and greater range you'll find they at least break even with the cost of buying several lead packs. I daresay they'll even be cheaper.
evric wrote: That's excellent Christopher, maybe get that red light to "throb" - even better! Eric
Can you imagine what would have happened in the garage? The brake booster wouldn't have had time to build up vacuum, and I doubt the brakes would have stopped her anyway...jonescg wrote: Good thing the start in neutral policy was adopted...
4Springs wrote: Any idea how to remove epoxy resin?
Well...evric wrote: Christopher, have you got a good precharge circuit in place?
Well spotted Eric, I didn't know that when I drew this circuit, but I found out once I built it! So I put in a diode or two so that the contactor (labelled BB in the diagram for Battery Box) is powered by ACC, ON, START and 240V. That contactor is therefore only rarely turned off since most of the time I am parked I am plugged into 240V. I bought a more expensive Gigavac contactor for that reason - the Gigavac has a low current usage while on compared to the cheaper one I used for the drive contactor.evric wrote: The circuit shows the contactor in the centre of your pack running off ACC. In my car ACC is turned off while I go to START. It should be wired to IGN side of the switch. Does your radio go off when you switch to START? If it does this maybe the cause of your problems.
Yes, you are correct.evric wrote: As the circuit is now, if one of the Emergency stops is left open and then after trying to start is suddenly closed this will put full voltage straight on the controller.
