Hey everyone,
I have some exciting and terrifying news. Katherine is pregnant! Yes, we're expecting a baby to change our lives forever in early October. Terrifying because I don't have job, but hopefully that will change very soon.
It also means that Voltron Evo will no longer be the first recipient of what little money I earn. That's going to have to go towards baby supplies and accessories. Granted we're going to borrow a bunch of baby stuff to save some money, but we are probably going to have to move somewhere slightly bigger with more distance between us and the neighbours. Ideally cheaper too. My angle grinder is pretty annoying, but only for a few minutes a day. Not all day... and night.
So I thought I might put some photos up of the progress to date, and list everything that needs to be done.
In order of most pressing -
1. Get the fibreglass fairings repaired and tank cover made. This means paying a firm $150 to paint the plug in two-pack urethane paint and polish to a glassy finish. Then I will take it to Glen and get a mould and final part made. I will get KiM (AussieJester) to join the cuts I have made to the fairings so it fits around the bike.
2. Get the frame painted. I will just go with an acrylic paint once the rust-proofing primer has been applied. The fairings don't need to be painted, but the frame will only continue to rust if I don't get onto this.
3. While the frame is apart, I can take the motor down to WA Gears and get a couple of front sprockets splined. Danny Ripperton has kindly offered to make me an alloy rear sprocket, but I can also buy a Ducati 44 tooth rear which would be pretty close to an ideal ratio (17:44, top speed of 220 km/h or so). An RK chain is about $250
4. Source and install a radiator for the bike. I don't have a lot of room, but any liquid cooled sports bike is bound to work in this case. As long as the wheel doesn't flex into the radiator under hard braking, I can make it work. The motor's continuous power is rated to 75 kW at 55'C coolant. The inverter can handle 90'C coolant - so I am confident about putting them on the same loop. I will also need a 12 lpm pump rated to 110'C for pumping coolant around the bike.
5. Place an order for ~540 LiPo cells about 5 weeks before I need them. This is about $6500. I can build the packs pretty quickly once they arrive - perhaps a week's work.
6. Place an order for a PM150DZ inverter.
7. Wire up the 12 V loom. This is pretty straight forward and affordable, but I will need to have the bike re-assembled to do it properly. I'll have it so disconnecting any component is easy. Things like the throttle, motor sensor wires, ignition start, precharge and ON features through the inverter... all needs some thought but nothing too crazy. I might start looming this out now.
So there you go. If I started a Kickstarter/Indegogo do you think there would be much support? I have no perks to offer except taking the finished product for a ride. There would be nothing to gain financially by helping me get this bike on the track, but you would surely see some decent racing. The first race of the season is June at Queensland Raceway, and if they don't have at least 5 bikes there won't be a series. So it's more than just my bike riding on it...
Interesting times ahead.
