This in a way suggests the death of Solar HWS.
Thoughts ?
Tritium_James wrote: The PV might achieve 18% efficiency, and a heat pump HWS might have a COP of 3.5 (ie pumps 3.5kW of heat into the water for 1kW of electricity use) so overall the PV + heat pump is probably less efficient at heating water than direct solar is.
carnut1100 wrote:
So I have a tad over five years of 1:1 and the system will be fully paid for before it runs out, so at that point I will be installing a battery pack that holds a day's generation so I only sell cheaply what I genuinely cannot use and I only buy when my pack hits 80% DoD which should never happen....
Now I want a wind turbine...
bga wrote:
The scheme:
Make up a 5 series x 2 parallel panel set and feed the element directly with an MPP (area=~13 m2). This will supply approx 9kwh per day on the cloudy months. or 32.4MJ. Approximately 23MJ is available to heat water.
Assuming inlet temp is 20C, outlet is 80C, this can heat approximately 80 litres per day.
Add a heat pump (COP = 2.5) and the total hot water could be 200 litres.
Compare this to a 30 tube collector, width ~2.4 metres, length approx 2m = area =~ 4.8m2. Collector efficiency approximately 75% (guess) => 16kwh per day, so 13kwh heating after losses or 46MJ or 160 litres from 20 to 80C and much smaller roof area needed....
