EV200 vs LEV200 contactors
Stiive
Post by Stiive »
Does anyone know the difference between the LEV200 and EV200 contactor?
Rgds,
Stiive
sorry i just carnt help my self
that is easy one has a L in the name
like i said sorry just had to be done
Stiive
Post by Stiive »
EDIT double post
Rgds,
Stiive
Stiive
Post by Stiive »
Adverse Effects wrote: sorry i just carnt help my self
Sorry, I just can't help myself.
That is easy; one has a L in the name.
Like I said, sorry, just had to be done.
Thanks.
It seems the LEV is bigger and cheaper. Doesn't seem to need an economiser [EDIT - has one included?], but uses more coil power.
Can someone confirm?
Rgds,
Stiive
zeva
Real Name: Ian Hooper
Post by zeva »
Pretty sure that is the primary difference, the LEVs don't have a coil economiser so use a bit more power when energised.
I'm more a fan of the EV200. Using 2W instead of 15W for the coil means they run cooler and should last longer.
Ian Hooper
http://www.zeva.com.au
The data sheets also indicate the mechanical life is different (not that it matters for an EV generally).
LEV200 100,000
EV200 1 million
You can google both.
Stiive
Post by Stiive »
Hmm thanks.
Unfortunately I need a 24V coil, but it doesnt seem that Digikey stocks this in EV200
Rgds,
Stiive
Stiive
Post by Stiive »
Stiive wrote: Hmm thanks.
Ah never mind... its 9-36V coil.. digikey just lists it as 12V or 48V
Rgds,
Stiive
TooQik
Real Name: Chris
Post by TooQik »
The open and close voltages are also different between the two. For example, the 12 VDC LEV200 has a close voltage of 9 VDC and an open voltage of 2 VDC, while the EV200 is 9 VDC and 6 VDC respectively.
The EV200 is also about 150 grams lighter if you're looking to save some weight. Image
These are all according to the data sheets I've read.
I believe the L version is longer, as well.
So: L is longer, heavier, more power, but cheaper.
MG ZS EV 2021 April 2021.
Stiive
Post by Stiive »
Thanks guys.
Didn't want to experiment and stuck with what I know.
EV200 for main contactors + LEV100 for pre/dis-charge
Rgds,
Stiive
