Spinning Solar Cell
Stiive
Spinning Solar Cell
Post by Stiive »
Looks good. Hopefully it's claims can be replicated on a commercial scale
Article
Rgds,
Stiive
Spinning Solar Cell
"Additionally, V3Solar claims the strobe-light effect on the solar cells hyper-excites the electrons, creating more electricity in the process."
Uh-oh! Sounds good but a bit of hype creeping in there.
Stiive
Spinning Solar Cell
Post by Stiive »
Johny wrote: "Additionally, V3Solar claims the strobe-light effect on the solar cells hyper-excites the electrons, creating more electricity in the process."
Yeh thats what i thought... sounds like a over unity sort of claim, but watch the video and it explains something about induced sunrise/sunset situations every spin cycle lol.
Rgds,
Stiive
Spinning Solar Cell
the cells output AC?
Spinning Solar Cell
Adverse Effects wrote: the cells output AC?
No I don't think they do but that's a thought. Place the cells in the correct configuration to generate a sine wave and rotate it in sync with the mains - no inverter required. We're bloody geniuses!
Stiive
Spinning Solar Cell
Post by Stiive »
"The Sentinel system uses a quarter of the silicon when compared to a similar 1kW array of traditional flat solar panels and an external solar inverter isn't required as the system outputs AC power."
Yeh it does... Apparently...
Rgds,
Stiive
Spinning Solar Cell
Stiive wrote: "The Sentinel system uses a quarter of the silicon when compared to a similar 1kW array of traditional flat solar panels and an external solar inverter isn't required as the system outputs AC power."
Well I'll be.... I wonder if it's an inbuilt inverter or they really do sync the spin rate.
Stiive
Spinning Solar Cell
Post by Stiive »
excerpt from video (1min 24s)
"....Producing significantly more DC than flat static panels. This electricity is then conditioned by the power electronics and transferred to the electromagnets in the base ring. As these spin past the electromagnets in the stator ring, AC power is produced, like a standard generator"
Rgds,
Stiive
Spinning Solar Cell
It's totally a scam.
If it had 20 times the output of standard flat panels, for the same area, or even if it had only 7 times, it would be more than 100% efficient. And if you don't know what's wrong with a claim like that, you probably shouldn't be on this forum.
See http://forums.whirlpool.net.au/archive/2000998
Also see some of the comments after the article here: http://www.gizmag.com/v3solar-spin-cell/24352/
Sure, cooling PVs is a good idea, if you can do it without using more energy (or money) than you gain. But even if you could get them all the way down to ambient you'd only gain 15%.
All the spinning does is bamboozle you for a while so it's hard to think about what's happening. It is in no sense tracking the sun so there's no possible gain from that.
And the "lenses". All they do is steal light from either side of the ones they are concentrating onto. "Dancing photons", "emptying buckets", complete nonsense.
Spinning Solar Cell
weber wrote: If it had 20 times the output of standard flat panels, for the same area, or even if it had only 7 times, it would be more than 100% efficient.
I got that right away, but assumed that the output increase was mostly due to concentration, and a little due to cooling.
But if they aren't tracking, then concentration is pointless.
Spinning Solar Cell
Some noob wrote: Used with a proprietary "Power Pole" mounting system, 10KW can be deployed in a 10 square meter space.
Given we get 1.4kW/m2 of sunlight on our planet they are running a total conversion efficiency of 71% - or they are from another planet...
Given the theoretical efficiency limit of a panel is 33% no amount of spinning, lenses or heatsinking can improve this 33%.
I wonder how they came up with the idea of putting cones and spinning together Image
Canberra32
Real Name: Damian butcher
Spinning Solar Cell
Post by Canberra32 »
I may just be a fabrication wiz and don't understand them fancy terms but...
How dose an equivalent built pyramid of panels pointed at the sun instead of a flat panel stack up in numbers?
Because there seems to be a whole lot of complication going on I'm not getting
Spinning Solar Cell
BTW, the 33.7% limit is only for single-junction cells. The limit for all types is 86%. The most efficient yet made is 44% (a triple junction that requires concentration) and that's in a lab, not commercial.
The 1.4 kW/m^2 figure is at the top of the atmosphere. At ground level it's only 1.0 kW/m^2.
So 10 kW in 10 m^2 would be 100% efficient. And none of this alters the fact that whoever is trying to extract money from people for this thing's "development" is an evil lying bastard.
[Edit: Changed "But still" to "So"]
Canberra32
Spinning Solar Cell
Ahh weber is right!!
That means he aliens that built the pyramids but couldn't afford to have their contractors put the panels up coz they lost the government incentives were on to something ;)
Stiive
Spinning Solar Cell
Post by Stiive »
I missed (and still missing) the part where it claimed to be 20x better. But I haven't read the article in detail
From a skim, it does say they use 1/4 of the silicon - and from the m^2 output it seems 6.667x more output.
But then, that's probably earth surface area. So considering base of the conical shape is 10m^2, the radius would be 1.784m. Assuming the cone is as high as it is wide, the hypotenuse would be 2.523m, giving the conical surface an area of 14.15m^2. (Obviously this area isn't orthogonal to the sun though)
Therefore this system gets 10kW for 14.15m^2. So really its only 4.7x better than the other PV cited.
Still that's bordering too close to (if not above) 100% efficiency already.
But hey, even if it only produces half its claim - you cant write it off. Maybe it is more efficient per m^2 and we will all have spinning pyramids on our roof in the future Image
But one does wonder about the type of people who make such claims which are obviously exaggerated - but perhaps there's some clause information we don't know about.
Anyway, food for thought, and a reminder to think outside the box.
Rgds,
Stiive
Stiive
Spinning Solar Cell
Post by Stiive »
Stiive wrote:perhaps there's some clause information we don't know about.
Just read they say there is a 30x concentration! Perhaps they have some mirrors set up to reflect more than 30*10m^2 worth of sunlight onto the thing (or in a lab shining a 30x concentrated beam)... Then it wouldn't be 100% efficient... infact it would be far less efficient than the other system - but the cost of PV per kw would be reduced and be replaced with the cost of the mirror array.
Then its a sort of marketing gimmick to give the output in terms of the space required only for the actual PV.
I'd say itd be spinning much faster than 60hz to keep cool!!! 1Mhz? haha. The faster they spin too, the more resistance and even lower efficiency - but hey, its all about the economics.
Just a thought.
Rgds,
Stiive
Spinning Solar Cell
Stiive wrote:Anyway, food for thought, and a reminder to think outside the box.
Hi Stiive. If I had a dollar for every time I was reminded to "think outside the box" ....
If I listed some of the things I have designed and built in my life, you'd see that I am very good at "thinking outside the box". But really:
Anyone can think outside the box. The real trick is not to think so far outside the box that you're thinking outside reality.
And that requires in-depth knowledge of the area concerned. Photovoltaics is one such area for me.
Spinning Solar Cell
weber wrote:Anyone can think outside the box. The real trick is not to think so far outside the box that you're thinking outside reality.
Keep in mind Stiive that we have been reminded to think outside the box by so many over unity and such di&@%^ds over the past few years that it's wearing a bit thin.
Stiive
Spinning Solar Cell
Post by Stiive »
Rgds,
Stiive
Stiive
Spinning Solar Cell
Post by Stiive »
Stiive wrote: Just like Aristotle had an in-depth knowledge of physics, which largely was accepted until Galileo 1,800 years later.
Weberian physics?
PS, not having a go at ya mate. Just a bit of fun Image
Rgds,
Stiive
Jeff Owen
Real Name: Jeff Owen
Spinning Solar Cell
Post by Jeff Owen »
Weber's "box" is actually a dodecahedron. I have seen it on his back verandah directly above the MX5.
Spinning Solar Cell
Weberian physics?
That's fine Stiive. But I would like to note that prior to Galileo the scientific method hadn't been invented (at least not in the western world), or to put it another way, there was no requirement that the pronouncements of Aristotle should be tested against reality, or questioned in any way. In fact you could be burned at the stake for doing so (eg Giordano Bruno). As it was, Galileo was "shown the instruments of torture" and kept under house arrest. Thankfully, nowadays you get rewarded, eg Nobel prize, for proving the previous guy was wrong.
Since you still think the "spin cell" is in with a chance, I suggest you buy one and bring it over to my place Image so I can measure its output. And if it's anything like they claim, then I'll take it apart to look for hidden power sources or energy storage. And if I don't find any, I'll happily announce this to the world. So you see, I'm open minded, just not so open minded that my brains have fallen out. Image
[Edit: Added "Thankfully"]
Stiive
Spinning Solar Cell
Post by Stiive »
Rgds,
Stiive
Stiive
Spinning Solar Cell
Post by Stiive »
Rgds,
Stiive
Spinning Solar Cell
I think you really ought to stop now Stiive. I'm quite sure that you would be surprised at the engineering prowess (and qualifications) of some of the folk that you are offending - just stop, OK?
