Post
by coulomb » Sat, 09 Feb 2013, 03:43
Canberra32 wrote: Yeah I copped a 200amp sap from not earthing the tig and holding the metal
If 200 amps flowed through your body, you'd be turned into a fireball in less than a second.
After skin resistance is overcome, the human body has around a kilo-ohm of resistance (from poor memory, and I'm too lazy to look it up). Power equals I^R, so that's around 200^2 x 1000 = 40 megawatts.
The 200 amps only flows through a very low resistance circuit, like the welding wire and air heated to a plasma state.
[ Edit: and with E = I.R, it would take around 200 x 1000 = 200 kV to force 200 A through a human body. ]
coulomb on Fri, 08 Feb 2013, 16:48, edited 1 time in total.
