coulomb wrote:Actually, I'm making a big assumption here, that the motor behaves like a 3-phase load on a sine-wave AC system.
However, many brushless DC motors use "6-step commutation", where only two windings are on at once. If you are not PWMing the outputs, then with star you would get two windings on at once, but with delta, only one. So if the motor has crude commutation like that, switching from star to delta would not be valid, and the motor would run extremely roughly, if at all.
IPM motors are somewhat between PM motors and BLDC motors, so I don't know where that leaves us. Suddenly, I'm not as confident that the star-delta rewiring will work. I think we need someone more familiar with IPM motors to chime in at this point.
I'm far from familiar with IPM motors, so please consider what I write below to be assumption and guesses.
Is it safe to say that the waveform that a PM motor would be happy with is the same as the waveform it produces at its output when spun by an external source?
For example, if one of these motors is re-wound to delta, the motor is spun, and the waveform observed at the terminals is sinusoidal, then the motor would happily run with a sinusoidal input. Likewise, if the output is trapezoidal, then it would want a trapezoidal input.
The fact that the rotor position is sense using hall effect sensors does suggest that it's a "6-step" motor, but if the absolute rotor position was known through the installation of an encoder/resolver, shouldn't it be possible to run the motor with any FOC controller capable of the voltage and current?
I've been fantasizing about using a Prius transaxle as an EV motor for a while now. Even better if I can put it in a car and have it just look like a transmission floating there with no engine attached, then drive away in it. Boggle people's minds
Really though, the Prius transmission, from MG2 through to the diff and output shafts, is a very nicely packaged unit with a (I think around) 8:1 ratio. It's like a mini version of the "holy grail" Borg Warner + Siemens motor. An enterprising entrepreneur would design a stand-alond cast aluminium casing into which the MG2, reduction gear, and differential from wrecked Prius transaxles could be swapped. I'm picturing a Subaru Impreza with one of these in the front, another in the back, and 120kW AWD.
</dream>
Still, 298vdc is still very high for a motor on a 8:1 fixed gear reduction (7000rpm @ 100kph). Does anyone know how many poles these motors have?
