Well 5 months later..
And the Niki's done a total of 8762 electric km's.
I have now retired the lead acid Optima batteries because they were getting tired and sagging lots and range was down to 15kms. Still useful for trips to work and back but I couldnt resist the lure of lithium any longer!
I estimate that the Optima's did approximately 800cycles mostly to only 30%DOD though. Will have to do some capacity testing on them soon to see how much AH they have left.
Anyhow the cost/km (battery cost only) was high at $0.3389/km. Quite a bit more than I was hoping for.
The average wh/km at the wall for the lead acid Niki was
161wh/km
The best was 115wh/km.
Now I have installed a pack of 36 x 60AH Skyenergy/CALB. So the car has gone on a diet and lost around 90kg!! So should be down to around 630-640kg now. The weight loss is really noticable the suspension feels softer and there is less body roll in corners now.
I have not done many km's yet but averaging 145wh/km at the wall after 300km. With the best single trip of 125wh/km.
For instrumentation I have just installed a Cycleanalyst HV so should be able to work out how effecient the chargers are soon.
For charging I am using the same Purecharge 10amp lead acid chargers and for the bms I have EV Power modules and the MCU(yet to be installed)
