Obsolete Thread
Locked
EV2Go's - Lithium Powered Trike
Post by rhills »
I tend to lean towards plastic for light weight and also corrosion resistance. However, here you may also have to worry about UV resistance, any idea how the plastic will stand up to UV?
What about price, up front and also if it has to be replaced down the track?
FWIW, the shiny plastic one looks nicer and I like blue!
Total Petrol: 720.1L
ODO: 61386
Av Consumption: 1.17 L/100km
EV2Go
Post by EV2Go »
Electrocycle
Real Name: Andrew
MSN: dumhed@dumhed.com
Post by Electrocycle »
I found an old metal one I'm going to use on my bike because it's easier to modify :)
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
Speedily
Real Name: Anthony
Post by Speedily »
The green motor looks like its got a whole new end cap made
EV2Go
Post by EV2Go »
Speedily
Real Name: Anthony
Post by Speedily »
Looks good
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
Speedily
Real Name: Anthony
Post by Speedily »
lol This is how i'm doing it Image
one of the injector hats mit look good on the end of the intake
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
It would be way more exciting (for us) if you ran the motor and held a hacksaw to the shaft. Image
No, I would not rest the armature on the field laminations while anything vibratary (word?) was done..
Edit: added 't'
EV2Go
Post by EV2Go »
EV2Go
Post by EV2Go »
Agreed - just take is easy and check temp. every now and then.
Are you sure you don't want to think about this for a day or two?
Removing all of the rear-end of the shaft may make putting a tacho or encoder on to the motor a bit more difficult.
EV2Go
Post by EV2Go »
Speedily
Real Name: Anthony
Post by Speedily »
Paul the criclip fan and spacer set the end float of the motor :)
EV2Go
Post by EV2Go »
Speedily
Real Name: Anthony
Post by Speedily »
whats holding the front bearing inplace
EV2Go
Post by EV2Go »
AirAg
Real Name: Peter Travers
Post by AirAg »
How did you manage to get your menu items to link to your following posts? I have just been replying to my first post when I put up new stuff and it looks like the URL is the same for the whole topic.
Peter
Locked
