Williams Electric Tilting Trike
- Real Name: Simon Williams
Williams Electric - Tilting Trikes
- Thalass
- Real Name: Ben Rypstra
Wow that looks great! It'll be good to see one in action.
Looking good.
I notice that Bunnings sell a 25mm wide strap with a grippy buckle that can hold 300kg for AU$8 here (Melbourne). They come in 100cm and 150cm lengths.Carv'n Marv'n wrote:Had a "great idea" to hold the batteries down with a velcro strap - but it's far too stretchy, so at a standstill till I can come up with another method... a strap of some sort.... large cable ties might do it.
Yes but the buckle isn't as bulky as most of them so it would make quite a neat battery strap. I was considering them for my 15kg Headway packs if I can't get the missus to make my webbing straps. They are a bit close to tolerance for me though as a 15kg pack at 20G make 300kg - borderline with engineer.
...to Bunnings!
I can't remember the brand but half of them were marked 100kg and half 300kg - so check.
That's dissapointing - sorry for the bad lead.
Would it help if you placed a piece of flat, firm material over the batteries length wise then strapped that? Say a piece of polycarbonate - no - something firmer.
If not, take 'em back and say they were too stretchy.
BTW - did you make the "electric" chrome badge?
looks great
just wondered if it will be stiff to lay over into a decent lean angle due to having individual shocks ?
i know you would like it to assist you to stand itself back up to a vertical state , so wondered if it might benefit from either a hydraulic valve between two gas shocks set up as a balancing or proportioning valve so it could give you a more free action of travel when you lean the bike to each side , or have a single main shock and a rocker arm pushing down on to both swingarms to give you a more fluid swinging action ?
looks Bl**dy fantastic though , hope you dont take my comments offensively
good luck.
- Electrocycle
- Real Name: Andrew
- MSN: dumhed@dumhed.com
you could swap any two of the phase wires, and the swap the same two hall effect signal wires.
You could otherwise just select reverse on one controller.
- AussieJester
- Real Name: KiM
- MSN: aussiejester@hotmail.com
Finally had some spare time too look over the forum glad i did !!! trike looks brilliant, i still think there will be issues keeping the front wheel on the ground though hehehe...:: subscribed ::
KiM
KiM
[url=mailto:emissions-free_worldwide@hotmail.com]For A123 Prismatic Cells[/url]
Recumpence.com[/u]...For RC Reduction Drives
http://tppacks.com
http://tppacks.com
