I'm looking at options to use the GS450h transmission package Phil is very generously giving me, still with a car wrapped around it so I get all the wiring harnesses etc.
There is a well documented conversion using the "Zombiverter" replacement control board in the 450 inverter and direct battery feed into the high voltage side so the current is no longer limited and the upper voltage is 650vdc, but no requirement to go that high. In this conversion, the input shaft is locked so the MG 1 (motor/generator) can add to the power produced by the MG 2 motor.
I'm toying with using the whole of the Lexus package, V6 ICE and the hybrid 2 speed 2 motor transmission using the Zombiverter controlled inverter and locking the flywheel on the V6 (yes, it does actually have one) for 100% EV use but having the V6 still there as a hybrid charger/assist if needed.
The proposed vehicle to be converted is a 10 mtr motorhome that has a V10 petrol/LPG ICE and a 6 sp Alison auto. If I limit the total torque to the equivalent of the V10 and direct drive the 6 sp Alison (no inverter), I'm looking at keeping the LPG and adapting it to the V6 Lexus engine so if I'm in an aera without recharging facilities, I could run the V6 to supply drive to MG1 to assist with power for MG2 and top up the battery as required .... it would also add to the total regen braking using compression braking as well with the LPG shut off ......
What am I missing here, I just have a feeling this sounds too easy/logical to actually work ........ Is it possibleMG1 & MG2 could over power the V6 ICE and spin it backwards rather than driving the vehicle forward under high load?
