2024 LDV eDeliver 7 electric van review: Australian first drive
I've had a lot of luck with the vgate Bluetooth adapter (about $50) but your best bet would be to find someone local and borrow one so you can try before you buy.Gordon wrote: Fri, 31 May 2024, 09:54 Can anyone recommend an OBD2 scanner and app that will definitely work with this vehicle sufficiently to see codes, see battery SOC, reset messages etc? Not getting much confidence from the suppliers I've contacted so far who can't say for sure what will work, and I'd rather not have to spend more than $250 for it.
TIA
I spoke to the LDV help line the other day, they tell me it has to be taken to a dealer/workshop to reset it. Nearest LDV EV dealer or workshop is over 300km away at Taree, so that wont be happening, which I hope wont impact the warranty, as I'm recording the required maintenance I do every 4000km.Gordon wrote: Mon, 27 May 2024, 18:38 the "Vehicle Maintenance Now" message appears each time we turn the car on, but there is no obvious way to reset it
