Had the pleasure of stripping a GWM ORA battery today, no video but I did get some photos
Came in quite a large box but the battery insde was (relatively) small. The packaging had CATL written all over it so I'm guessing they are the cell manufacturers.
The lid appears to be a very thin layer of carbon fiber that is bolted down with a gasket (no glue or silicone)
Underneath is another bolted on panel, steel this time. Which after being removed, gives you access to the cooling plate which covers the whole bottom of the battery as 1 big piece.
Liquid cooling ports, HV connection and 12V power/communication
The pack is 47.8kWh. Made up of 131Ah LFP cells configured in a 1p 114s layout. Nominal voltage is 364.8V and there are 3x 18s modules and 5x 12s modules. All the busbars in each module are welded (laser welded I think? I'll need to have a closer look) with flexible circuit boards attached to the cell tops for the cell monitoring. All the cell monitoring goes to plugs at the outside edge of each module where it then connects to a harness which leads to 2x large BMS ECUs mounted in the centre. There is a small 3rd ECU in the middle as well, not sure what that is yet, I suspect it's an interface module to take messages between the BMS and the rest of the car. Contactors are controlled by the BMS directly and there is both a hall effect style current sensor and a current shunt inside the contactor assembly
