BYD plans
BYD EV Interest Group
BYD plans
I've started this forum because BYD seem to have plans for Australia. I'm not sure what to believe about some of the claims made by the importer, Nexport, e.g. a 500 km range car for under AU$35 000 by early 2022.
A 2017 article about the first Chinese EV in Australia, a BYD E6: https://www.bluemountainsgazette.com.au ... the-noise/
BYD electric vehicles to be sold in Australia from 2022: https://www.caradvice.com.au/923350/exc ... from-2022/
NSW is getting an electric car manufacturing facility worth $700M: https://www.caradvice.com.au/893706/nsw ... 0-million/
MG ZS EV 2021 April 2021.
Wil
Re: BYD plans
Post by Wil »
They are going to be at the Smart Energy Expo in Sydney 12th and 13th May. They will have the BYD HAN on display.
Wil
Re: BYD plans
Post by Wil »
Here is a bit of google translated manual for the 2021 e2- seems to have 3.3kW vehicle to load
VTOL discharge method outside the car 1. Equipment description:
█ Vehicle-to-load discharge connection device (VTOL): This device consists of a discharge gun, power strips, cables and a discharge gun protective cover.
█ Equipment specifications: Rated 220V 50Hz 16A discharge outside the vehicle is realized through VTOL connection, and the maximum discharge power is 3.3kW.
2. Discharge operation guide
█ Before discharging, the power gear is in the "OFF" gear.
█ Unlock the switch of the charging port cover, open the charging port cover and the charging port protection cover.
Q See unlocking the charging port cover for household portable AC charging, and open the charging port cover and charging port protection cover.
BYDEL04013
4
Use and drive
106 4-1 Description of charge and discharge
█ Check before discharge:
Q to ensure that the total power of the discharged vehicle is not less than 15%;
Q Make sure that the VTOL connection device has no abnormalities such as shell cracks, cable wear, rusty plugs, or foreign objects;
Q Make sure that there is no water or foreign objects in the charging port, and the metal terminals are not damaged or affected by rust or corrosion;
Q If the above situation occurs, charging is prohibited, otherwise it may cause a short circuit or electric shock, which may cause personal injury. █ Instrument settings:
QPress the discharge switch on the light switch group (when equipped), and select the VTOL discharge mode on the meter.
█ Connect the discharge connection device:
Q Connect the discharge gun of the VTOL discharge connection device to the charging port and lock it securely.
BYDEL04014
BYDEL04015
Tips
Do not forcibly insert the discharge gun when the electric lock is locked.
Re: BYD plans
I see they will be releaseing a couple of vans here shortly, and they are priced quite sharply too. $35k or something. Any tradie worth their tax concessions would be mad not to get one.
