In Shepparton the free type 2 22kwh chargers immediately initialise and start charging as soon as you plug in without any other procedure……..and effectively stopped by using the unlock button on your key fob……at least with the MG.
I can’t recall a faster simpler setup.
The Mennekes cables provided are tethered but I think they should be under surveillance 24/7 ……they are valuable.
Charger controlled by your key
Re: Charger controlled by your key
I find with mine (manufactured 7/12/2020), pressing the button on the driver's door handle also stops the charge. I think I read somewhere that this is supposed to be a way to get into the car without stopping the charge.
- Real Name: David
To me at least it seems odd that the plug release zzzz is accompanied by a signal to the charger……hmmm…..perhaps something called an instant load shedding situation causes the charger to shut off because the car’s charging solenoid isolates the battery on the key/handle button signal.
- Real Name: David
I don’t know if this info applies to all non Teslas, but I stopped the home wall charger also by using the key fob ….rather than via the unit’s control face which I had always done before.
Just more magic.
Just more magic.
