i3 and i8 drive ratio
Posted: Fri, 14 Sep 2018, 10:24
I have been watching an assembly video on the drive train for the i3 and i8
They appear to have reduction gears in the transmission with around a 1:4 and 1:6 reduction ratios ( 1 : 24 total )
If the drive tyres have a diameter of 27" ( 20 inch rims ) , that means the tyre circumference is around 2155 mm
wheel RPM must be 860 RPM to provide 110 kmhr speed.
860 RPM at the wheel / 1:24 ratio means the motor would have to do 20640 RPM
I cant see anyone going higher than 6000 - 8000 RPM in a drive motor.
Whats wrong in the numbers ?
scroll forward to 1:50 on the video to see the gear ratios.
[tube]https://www.youtube.com/watch?v=xvaQMTcckSg[/tube]
