Hi all - have just completed and uploaded to the AEVA website a Fact Sheet on the Mini Cooper electric. Will work on improving it further once a few more details come out - I couldn't get the car width for open and closed mirrors for instance.
Note this is to the new Version 7 Fact Sheet template. Now includes 0 - 100km/h time plus a couple of other items.
Bryce
P.S. Porsche Taycan will be the next Fact Sheet. BTW: anyone got a Taycan to offer me a test drive of?
Mini electric fact Sheet now up on AEVA website
- Bryce
- Real Name: Bryce Gaton
Current EV drive: 2019 Kona electric, 2010 iMiEV
- jonescg
- Real Name: Chris Jones
Re: Mini electric fact Sheet now up on AEVA website
I'll try and get the Livewire write up for you too
- lopezjm2001
- Real Name: John Lopez
Can you provide a link to this fact sheet? Thanks.
2016 BMW i3 94AH
- jonescg
Just a few corrections for the fact sheet. I realise you are probably just quoting the manufacturer data, but the real world tested data is quite different, especially in warmer parts of Australia.
1) The WLTP range is actually quite good. I am getting around 250km in mixed driving. To get only 200km, you would need to go at a constant 110km/h.
2) My average kWh/100 is around 10.5-12 depending on how much fun I have. At 120kph, the mini uses 17.8, and at 90kph it uses 12.8. 15 would be around 110kph continuous. An average of 15kWh/100 with a 28.9kWh battery would suggest a range of only 190km.
3) The third thing is the 0-100 is woefully wrong. The correct figures are 6.3s (0-60mph) and 6.6s (0-100kph) as tested by multiple sources (not manufacturer claimed).
4) The usable is 28.9kWh
The width with/without mirrors is: 1928mm/1727mm according to the manual.
Jsvader - are your kwh/100km figures quoted by the car? or are you measuring on recharge (AC pulled from the wall)?
The later is generally used for comparing EV efficiency, as it includes all the round trip losses
2023 BYD Atto 3 - 21k km
2017 Renault zoe - 147'000km
2007 Vectrix - 50k km
- Bryce
Hi jsvader: Probably I should have left a few of them as TBC really - but was trying to be at least partially helpful.
I normally only quote official numbers from a particular set of sources in all parts of the Fact Sheets. Avoids the argument on who is 'more right' if I stick to one set of official sources. (Usually that's the Aust government Green Vehicle Guide for quoted range and kWh/100km and US EPA for real-world and manufacturer for all other vehicle data) - but the Mini electric isn't listed on the GVG site, so for the moment I'm using the manufacturer's numbers (which are slightly incomplete at present!), NEDC and/or WLTP. When it's listed on the GVG site, I'll replace it with those figures when available to keep it the same as all the others.
Also annoyingly, not all the manufacturer data is yet available - owner's manual would be useful, but there is no owner manual available for the Mini electric on the web yet. (I often refer to online owner manuals when checking data for the Fact Sheets).
Note: the 0 - 100 figure is the manufacturer quoted number in the brochures. What the leadfoot (or nervous Nelly) motoring writers with erratic stopwatch fingers come up with is too subjective for me
BTW: US EPA range for it is only 177km. I am watching that number for a revision, seems way too low. Hence I picked a 190km number as a more likely figure for the range section. (And Rye Hotel has a 3 phase AC charger ) Thanks for confirming it is OK.
FYI: Don't get me started on GVG using NEDC figures - which is why I use US EPA for the 'real-world' range quoted in all the Fact Sheets
Provided I use the same source (GVG) for the kWh number for all EVs, it will give a comparison figure - even if it's not the full picture.
Oh - and I rounded the 28.9 to 29 kWh. Watts 100Wh between friends?
Bryce
Bryce
Hi Bryce,
That is what I thought. You can't really do anything but that. I have the manual - that is where I got the width figure from I find the WLTP figures far more accurate than the EPA. The EPA use a "0.7 fudge factor" which takes the actual range obtained under experiment and multiplies by 0.7 to "simulate" the real world. Works for some, but not all cars. The Taycan was *way* off, as is the mini. I think your assumptions are probably a good approximation - and it is always a good feeling when you better the stats for any car
As far as 0-100, I only accept vbox/hardware timing (not stopwatch or frame grabbers). The most recent "Car and Driver" test was actually even faster. They went to a drag strip and got 6.1s 0-60mph, and 14.8s 1/4 mile - all professionally timed. That makes the little beasty quite a quick little beasty.
antiscab - yep, car measured not at the "pump". The car measurements are more for calculating range, whereas the pump is for price/km. You could have 100kWh of losses and you car will still go the same distance as if you had 0kWh losses. It would cost a lot more though per km
