Looking for a new BMS system for
14x LiIon 18650 batteries with a storage capacity of 30kwh
Volt maximum 57v (60V overcharged) Li Ion 18650 cells 14x parallel with maximum 4.10V each.
Currently I still have the old "DIY BMS 2.0" running, which is good except for the communication bus.
What alternatives do you have running or would you recommend
My plant about 1-2 years ago. Just more batteries now
DIY Powerwall Home Drive V2
Looking for a new BMS system for 14x LiIon 18650 batteries with a storage capacity of 30kwh
- Real Name: Dirk
30 kWh Akkuspeicher aus 3400x 18650 LiIon
+ Solaranlage 6,3 kW + 2x PIP Inverter 5048 und 1x PCM60x
Facebook HomeDrive V2
Youtube HomeDrive V2 - DIY Powerwall https://www.youtube.com/channel/UCrzB5r ... Ijk9vCDfuQ
