Goodwe SBP 3600 / 5000 series Hybrid Inverters
lobster
Real Name: Steve
Post by lobster »
I recently received a Goodwe SBP 5000 & ZEVA BMS16 v3 kit, and most of the components to complete a portable UPS system with my AVASS batteries.
Thanks for the advice of forum users who helped me select these components. This will be a good project to keep me off the streets.
The SBP Series User Manual has a QR code Link for a Goodwe EzManage App to setup & control the inverter.
The EzManage App is not available on the Android Play Store, but unofficial sites have older EzManage .apk versions for download.
Are these versions of the EzManage App safe to use from unofficial sources?
What software have SBP owners been using to setup & monitor this inverter?
Cheers, Steve
Re: Goodwe SBP 3600 / 5000 series Hybrid Inverters
Post by reecho »
PVMaster for setup and monitoring locally. SEMS Portal for monitoring everywhere.
