Grid Tied Wind Turbine - Champion Lakes
adam lippiatt
Real Name: Adam Lippiatt
Post by adam lippiatt »
Hi
I saw something like this:
https://www.ebay.com/itm/TECHTONGDA-400 ... SwWw1a6Usu
at Champion Lakes today. It was sitting on the top of a roof, not elevated on a mast. Unfortunately I didn't have time to knock on the door and ask about it. [There was conduit, it didn't appear to just be being used to scare off the pigeons (if anyone knows about Champion Lakes and their pigeon problems).]
I expect wind at a few metres above the ground is not going to make a lot of power, but someone has gone to the trouble (and Perth is a windy town).
Has anyone got any positive experience with integrating a small wind turbine in a grid tied setup in Perth (surrounds) and getting past the local council / neighbours and making useful power?
I currently have a 3kW grid tied solar setup with a Powerwall 2 and it would be interesting to have the batteries lean on another generation source during periods of low insolation (as usual, it's the end of the day and there is only a faint glow of the sun on the sky but the wind is more than rustling the leaves).
Adam
Re: Grid Tied Wind Turbine - Champion Lakes
Was this across the road from the aldi? The same place with the solar on trackers ?
adam lippiatt
This one is on Barrington Avenue. I will knock on the door next time I am passing.
