3-phase hybrid inverters?
Post by jonescg » Sun, 28 Apr 2019, 19:39
Edited - I'm broadening this thread to any 3-phase hybrid inverter...
https://www.solaronline.com.au/9000w-im ... erter.html
Does anyone have experience with these inverters? It seems like a solid product, and with plenty of power it won't have any trouble managing a 7 kW EV charge from a battery.
It's good in that it's a DC coupled 3-phase hybrid inverter, but man its not cheap. Best part of $7000. Not sure I can justify installing this beast, but it's nice to know there are 3-phase inverters out there which can work on battery voltages less than 400 V DC.
Re: IMEON inverters?
Post by coulomb » Sun, 28 Apr 2019, 21:28
Not directly at all. However, I've heard more than a few grumbles over at the Power Forum.
Every inverter has its failures, and many suppliers can be obstinate about replacing expensive parts that blow up. But I would hope for better, especially at the price.
https://powerforum.co.za/topic/1425-pic ... 6-failure/
Post by jonescg » Sun, 28 Apr 2019, 21:48
Hmmm, wonder if they fixed their corrosion issues by now. We're a long way from the sea but the inverter would be pretty exposed...
Re: 3-phase hybrid inverters?
Post by jonescg » Thu, 01 Aug 2019, 10:12
So I have been looking harder for an inverter which will suit.
I have a three phase grid connection, but the only three-phase appliance is the reverse cycle aircon. I think it's a 3 kW unit.
Western Power demands that any three-phase connected home have loads balanced across all three phases. It also states that you cannot feed more than 3 kW back on one phase (the limit is 5 kW single phase, 10 kW three phase, but no more than 3 kW single phase if it's a three-phase home).
It would be easier if I can find a 3-phase hybrid inverter with the following attibutes:
- it is a single unit (not three units)
- it is IP65 rated. The location is exposed, but I do hope to put a shelter of some kind out there.
- it operates on a three-phase grid connection
- it has two MPPT inputs, as I have an east-west split rooftop
- it operates on a 48 volt battery with minimal BMS communications - the BMS can look after itself.
There are some inverters which meet these conditions except one, usually the voltage of the battery (eg the Goodwe ET series or the Fronius hybrids, which does 3-phase, but needs a 150-600 V DC battery)
Any experience out there with this dillema?
Post by jonescg » Thu, 01 Aug 2019, 11:09
Looks like the MPI 10K series from MPP Solar look like the best option, however they are not currently AS4777 compliant (as far as I can tell).
https://www.mppsolar.com/v3/mpi-hybrid-series-2/
Post by brendon_m » Thu, 01 Aug 2019, 12:19
According to the features tab (third tick up from the bottom) they are compliant
Post by jonescg » Thu, 01 Aug 2019, 13:05
Yeah and I just had the Australian rep confirm AS4777 compliance. I think it would just be a case of convincing Western Power it's good to go.
As to the quality, well we'll have to wait and see :)
Post by coulomb » Thu, 01 Aug 2019, 18:00
Also, it's IP20, a little short of one of your criteria :o
Post by jonescg » Thu, 01 Aug 2019, 18:26
I expect to build an undercover area there so the wall would be protected from any water regardless.
I was sent a copy of the AS4777 compliance document. I note that while the MPI 10k inverter meets AS4777.2:2015 Western Power demands it meets the 2016 regulations:
https://westernpower.com.au/media/2495/ ... 170828.pdf
Is this an issue? I suspect it might be as the 2016 regs included update concerning DRED and communications...
Post by jonescg » Wed, 07 Aug 2019, 20:21
While the hot water system was being installed, the sparkies had the cover off the meter box so I could have a look at what lies beneath.
*Daryl Kerrigan voice* See that three-phase A/C system? Fake ;)
Turns out it's single phase! Makes sense because it only ever drew about 3 kW full tilt. Only the left most breaker has anything attached to it.
But you can see that the east side of the house is on L1, the west side is on L2 and the lights and shed are on L3. There is no reason this couldn't be a single phase home, but the downgrade to single phase costs about $850. So I might try and stick with three phase if I can.
